It is currently Sat Jul 21, 2018 6:43 pm
PostPosted: Mon Oct 09, 2017 6:31 pm
Throwing the RZ up for sale. No hurry nor need to sell but if someone is interested in a nice modified bike, this would be the one for you.
Running the airtech bodywork which has been custom modified to fit the F2. The bodywork was cleaned up to look less rough as it comes from Airtech. Fitment for the belly to upper was improved as well. Tail is an unknown make but apparently similar to what John used to make. Think it drops the very long look the normal YZR tail has. Paint is a flourescent orange/red. As close to the original 1990 bike as I could find. They were not red, nor is this. Decals used for the Marlboro in black otherwise painted on. Frame and wheels are powdercoated.
30mm roundslide carbs with Uni pods
Micron pipes
Zeeltronic ignition
Solid state battery
Larger radiator
Stiffer front end and suzuki rear shock.
HH pads, braided lines. Best brakes I have had on a stockish RZ.
Aftermarket clip ons.
Avon tires with lots of life.
These are the major items but not exhaustive.
Pics here:
https://drive.google.com/open?id=0B_p5v ... HlDbGxId3M
Most were taken before I put on the windscreen but it is the smoked one seen in a couple pictures.
Not running signals or a speedo. Miles estimated at around 25k kms on chassis and a thousand on the motor. Haven't ridden it much. Bar end mirror. Brake light is there but not the most visible.
This bike is basically how the RZ should have come in my opinion. It turns, brakes, feels fast and is fun to ride. Miles better than a stocker. The riding position is quite a bit more aggressive.
Ab registered.
$5500.
PostPosted: Tue Oct 10, 2017 4:48 pm
That thing is sick! Where are you located?
PostPosted: Tue Oct 10, 2017 5:57 pm
Oops. That might Help.
Calgary, Alberta, Canada.
Could be convinced to deliver to Sweetgrass Montana as well likely.
PostPosted: Wed Oct 11, 2017 12:09 am
Yeah, it's a great looking bike. Evan and Dean did a great job on her. I've seen it in person.
