RZ Frame modified MOTO3 project
Road racing, drag racing, motocross, vintage - anything racing related discuss it here!
ulsterman
Re: RZ Frame modified MOTO3 project
#61 Post by ulsterman » Mon Jun 09, 2014 9:48 am
Thanks Dana for the updated pictures
I havnt been able to do much for the past couple of months becasue busy with other pressing family problems
On the technical side most of the electroics is done and should be ready to test soon
The latest picture shows the battery install under the seat and the wire harness
The battery is an EVO2/12 which at 430cca and weighting in at under 3 lbs is just unreal tech
Thanks for looking and will try to post alot more updates in the next few weeks
Consciousness
#62 Post by Consciousness » Wed Aug 27, 2014 3:32 am
Really enjoying your build, hope there's more coming.
nokturnal
#63 Post by nokturnal » Sat Sep 06, 2014 2:44 pm
Update from Laird -
:smt017
ulsterman
#64 Post by ulsterman » Sat Sep 06, 2014 2:56 pm
Thanks for the picture updates
The last one is of me racing an RS125R in this years Ulster Grand Prix ------I been away racing in Europe since July and doing the high speed track and calculations on the WR250R motor it has been replaced by a CBR250R to allow me to run speeds of over 130mph with the primary ratio of this motor at 2.8 able to do that ---------Hopefully will have a video shorty of the whole thing running -Fingers crossed cause there is always so many thing can and do go wrong -----Have a made a few mistakes on this one and im sure there will be more but we will keep trying
ulsterman
#65 Post by ulsterman » Mon Nov 03, 2014 11:43 pm
https://www.youtube.com/watch?v=Iuq832j ... e=youtu.be" onclick="window.open(this.href);return false;
Sorry been awhile
this is the first mechanical turn over and check of the bike -cam timing has been changed and injectors put into the barrel
There is also a few new pictures coming via a friend on here for me -----------Ps you will see the tank has changed as I used the one that came with the donor bike and already has a pump and everything I needed
Target is for this years motorcycle super show in Jan in Toronto -God willing
On with the electronics and hopefully next video will have something more barring no more mess up by me lol
nokturnal
#66 Post by nokturnal » Tue Nov 11, 2014 11:38 am
:smt017
nokturnal
#67 Post by nokturnal » Wed Nov 19, 2014 12:32 am
:smt017
nokturnal
#68 Post by nokturnal » Mon Mar 02, 2015 1:46 am
updates from Laird
ECU programming -
:smt017
ulsterman
#69 Post by ulsterman » Mon Mar 02, 2015 9:26 am
First picture is the newer rad - the zx6 rad doesnt work on the frame well so was replaced with an NSR250R one and the 5/8 coolant line and position is a direct fit
The next is the temp hook up of the second exhaust coming out the left side as the first pipe is in the original position and requires no mods
The last is Zoltan doing the new ECU frrom the ground up and as you see not an easy task but will be worth it in the end because gives me full control of the engine management system and heads up touch screen display
Thanks for looking
#70 Post by hondaror » Mon Mar 02, 2015 2:04 pm
Very cool project. Thanks for sharing.
ulsterman
#71 Post by ulsterman » Tue May 05, 2015 12:04 am
Sorry its been awhile but there hasn't been much progress with the Moto 3 as I am still wating on the ECU to be completed but in the mean time made the decision to put money towards the Bigger RZ project and at least get it started
The link below is the Facebook page for it
The rear end is from and NSR250R and the rest has been designed by me
This project should be on the track very soon as its a lot less complicated than the Moto3 and I need seat time !
#72 Post by hondaror » Tue May 05, 2015 12:57 am
Comes up as currently not available on Facebook.
ulsterman
#73 Post by ulsterman » Tue May 05, 2015 11:00 am
Removed
Amboyy
#74 Post by Amboyy » Mon May 25, 2015 10:51 pm
Mega tastee!!!
JanBros
#75 Post by JanBros » Sun Jun 21, 2015 8:52 am
nokturnal wrote: Image
one of the weirdest projects I've ever seen. (the weirdest being this one : http://www.kr-1s.co.uk/forum/viewtopic. ... ilit=rs125" onclick="window.open(this.href);return false;)
* on this pic it seems like the front sprocket is still above the centre-line between rear axle adn swingarm-pivot. like said before : it'll never work unless in some weird circumstances, but road-racing certainly isn't one of them.
* you never explained where the compressed air for injecting is coming from. Care to give more details ?
if it runs, you can race it !
