OEM LC Parts
OEM LC Parts
Ordered some OEM fork seals for my 4L0 from local Yamaha dealer.
Holy Carp was that a task. This dealer is the biggest in the city and they didn't have any easy access to a digital fiche. All the parts guys kept wanting to use the US based digital fiches but the LC was never sold in the US so it doesn't appear in the fiche systems.
It finally took an older, more experienced parts tech to find the part number. And then he wasn't sure what comes in the package.
I was after fork seals and the price for the part number is $40. I ordered two. So I will either get a pair of ludicrously expensive seals or I will get two sets of fairly expensive seals. I won't know for a couple weeks till the parts arrive.
Unfortunately for stuff like fork and engine seals we don't really have a lot of choice as the aftermarket parts are not very good.
Re: OEM LC Parts
I look up all my own part numbers.
Just go to rd350lc.net
http://www.rd350lc.net/RD350LC-4L0-82eng.pdf
And the dealer will tell you if the number has changed or still available.
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
Re: OEM LC Parts
Fork seals can be bought for any mass produced bike, in a lot of places. There are good aftermarket seals available. Worst case scenario, if you come across junk aftermarkets. They are cheap to replace. I've bought a few sets of cheapo aftermarkets for other vintage bikes and never had a problem with them. They only cost me around 10 bucks. The big thing, is inserting them in the correct direction and keeping your tubes somewhat clean. Some items as you mentioned are important to buy oem. Fork seals isn't one of them.
- two-stroke-brit
Re: OEM LC Parts
I feel your pain hooligan .
Re: OEM LC Parts
I've had two sets of fork seals from Yambits and they fricken bleed oil constantly. Super annoying! With the work required to replace them I'd rather spend a few bucks to have a set that actually works.pearljam724 wrote:Fork seals can be bought for any mass produced bike, in a lot of places. There are good aftermarket seals available. Worst case scenario, if you come across junk aftermarkets. They are cheap to replace. I've bought a few sets of cheapo aftermarkets for other vintage bikes and never had a problem with them. They only cost me around 10 bucks. The big thing, is inserting them in the correct direction and keeping your tubes somewhat clean. Some items as you mentioned are important to buy oem. Fork seals isn't one of them.
Re: OEM LC Parts
I feel ya, on that. A set should last for a long time. Just stating that I have never had a problem with aftermarket seals. I've used Bikemaster, All Balls, etc. Knock on wood never had a problem. A tiny pit of rust on fork tubes, can be the devil regarding fork seals of any make. A lot of times, it's just that. Dirt gets pushed into the seals, tiny rust pits that we may not see cut away at the seals given time. That can happen to any brand name. But, there is junk out there for sure.Hooligan wrote:I've had two sets of fork seals from Yambits and they fricken bleed oil constantly. Super annoying! With the work required to replace them I'd rather spend a few bucks to have a set that actually works.pearljam724 wrote:Fork seals can be bought for any mass produced bike, in a lot of places. There are good aftermarket seals available. Worst case scenario, if you come across junk aftermarkets. They are cheap to replace. I've bought a few sets of cheapo aftermarkets for other vintage bikes and never had a problem with them. They only cost me around 10 bucks. The big thing, is inserting them in the correct direction and keeping your tubes somewhat clean. Some items as you mentioned are important to buy oem. Fork seals isn't one of them.
Re: OEM LC Parts
I went through the dealers etc for oem parts & got sick of being ripped off.
Bob_yp is one of my go to guys now. Most everything rz or lc ill get through him. If he's not advertising it ill email him & 90% of the time he can find it & at pretty damn good prices too. Easy peasy to deal with.
Re: OEM LC Parts
+12smoke wrote:I look up all my own part numbers.
I don't even think about calling the dealer without the part number in hand. Most don't have a clue.
Re: OEM LC Parts
Hey if the fork seals in your LC are leaking it's because they are the OEMs. I can't remember if I replaced the OEMs on your bike, but I know a brand new set of frickin expensive OEMs leaked instantly. I buy nothing but Pyramid seals now, 3 sets and haven't had an issue, plus you can buy 4 sets for the price of the OEMs. Just sayin.
Re: OEM LC Parts
Hmmmm. The original set leaked badly so I replaced them with a set from Yambits which did basically the same thing. With all the Yambits bills I assumed you had gotten them fr there.solo 2 wrote:Hey if the fork seals in your LC are leaking it's because they are the OEMs. I can't remember if I replaced the OEMs on your bike, but I know a brand new set of frickin expensive OEMs leaked instantly. I buy nothing but Pyramid seals now, 3 sets and haven't had an issue, plus you can buy 4 sets for the price of the OEMs. Just sayin.
At the cost of the OEM ones I just bought, I hope they don't leak. Silverstrom always harps about using OEM which is why I went that route. If they leak I'll send him the bill. :)
Re: OEM LC Parts
So the mystery parts finally came in. Each "kit" only contained a single fork seal making the end price a wee bit eye watering at $41 per seal.
I am going to be sending the forks down to a professional to make sure everything is in spec and prob get some damping work done. If I am paying over $40 for a fork seal I want them to work and last for as long as possible.
Re: OEM LC Parts
Norbo sells those for 11 gbp's a Pair.
Re: OEM LC Parts
Yambits fork seals are shit. Used them on my painter's bike (not my idea) and they leaked instantly. Absolute garbage.Hooligan wrote: Hmmmm. The original set leaked badly so I replaced them with a set from Yambits which did basically the same thing. With all the Yambits bills I assumed you had gotten them fr there.
I've never had Yamaha fork seals leak. Ever. Just ordered a pair for my TZR last week. $16.46 each.
If your new Yamaha seals leak you're just unlucky. Make sure they aren't rock hard from sitting on some shelf forever. If they are hard, don't pay for them and insist on replacements.
Re: OEM LC Parts
These seals seem OK. I have not opened the packages but they don't feel like they have hardened up.silverstrom wrote:Hooligan wrote: I've never had Yamaha fork seals leak. Ever. Just ordered a pair for my TZR last week. $16.46 each.
Where do you order your OEM parts from? I went to Blackfoot Motorsports here in town and the prices are eye watering.
I talked with a local mechanic and he suggested the lower bushing may be worn which allows the inner tube to flex slightly in the outer tube which then wreaks havoc with the seal. I have a second set of forks so I think I am gonna look at mixing and matching parts to get the best possible fit between inner and outer tubes before I install these uber expensive seals.
- OldTZracer
Re: OEM LC Parts
I've never had a problem with Yamaha seals. If I see any rock chips in the tubes, I run a stone over them so they don't damage the seal lip...
