Micron exhaust pipe position
Having issues with the centre stand smacking the microns when the pipes hung on the inside of the bracket. Solution - move them to the outside as photo'd . Now the microns look splade out, hmm. Where the microns only used by allowing side stand use only?
- IMG_2908.JPG (252.92 KiB) Viewed 5011 times
Re: Micron exhaust pipe position
Mine hang on the outside and not running a center stand. The silencers are pointing somewhat outwards. Would be interested if mine are hung incorrectly.
- RZResurection
My guess is that they were meant for the inside - looks cleaner.
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Milled Head (0.020")
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
Interestingly when I review rebuild photos, the pipe hangers on on the inside with the centre stand attached- abeit a broken centre stand later replaced. Looked at this video and noted the pipes on the inside on its center stand. Must have something to do with the flange rotation at the exhaust ports. Back to the bike.
https://www.google.ca/url?sa=t&rct=j&q= ... -jZRHac74w" onclick="window.open(this.href);return false;
- RZResurection
Im not sure what the mounting flanges look like. Can the pipes be easily rotated about the flange? If you have access to a grinder with a zip it disc and a welder, you could cut the rear mounting bracket off, rotate the pipes and reattach the bracket. That way you could set the bracket behind the rearset and still get a decent pipe position. I did this for my stock pipes so that they cleared my fat rear tire.LC Cnd wrote:Interestingly when I review rebuild photos, the pipe hangers on on the inside with th centre stand attached- abeit a broken centre stand later replaced. Looked at this video and noted the pipes on the inside on its center stand. Must have something to do with the flange rotation at the exhaust ports. Back to the bike.
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
They should be on the inside. If the centre stand still fits when you install new pipes, the new pipes are $h!t. The pipes need to be mounted centrally for cornering clearances. The new ones should be larger than stock, or the performance increase just isn't worth the change. Just my $0.02.
So what your saying Rory is side stand only?
That tends to be the case wilth most decent pipes.LC Cnd wrote:So what your saying Rory is side stand only?
- RZResurection
That's why they make race stands.LC Cnd wrote:So what your saying Rory is side stand only?
Good pipes are worth loss of the centre stand
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
Because it's about performance, not convenience.
Most definitely!LC Cnd wrote:So what your saying Rory is side stand only?
My TSA pipes fit with side and center stand fitted... I dont know anyone who would say a TSA pipe is shit...
Be saving up for TSA's next, cash flow permitting. Was able to rotate the pipes, but the centre stand frickin touching against the inside of the Microns. Inside it is - cleaner lines. Left pipe is on the outside as noted in the photo. Not for long.
- IMG_2910.JPG (184.92 KiB) Viewed 4868 times
- IMG_2909.JPG (181.43 KiB) Viewed 4868 times
Sighhhh.
Microns FIT on the inside of the Ali bracket. Truth is they don't fit overly well 'stock' Badly made ? OR crap assembly Jig, as a guess.
. I've cut off the mount bracket made a fresh one , rewelded it on
so the Microns fit"perfectly', nice 'n tight to the frame NO touching and the Slip fit joints are concentric and free to move. .
They Do not as made/sold.
TSA pipe's, while pretty, offer only Small Power advantages over Microns ALL brochure babbles /bs aside.
Microns Are noisy though and Do need repeated repackings
With regard to re-packing the Microns Bare, was told fiberglass building insulation would suffice. Thoughts?
