Kenny Roberts RD gold wheel addition (LOL)
Re: Kenny Roberts RD gold wheel addition (LOL)
Thx. Like to ying about Jericho beach this Summer if I can figure out why my Mircon (right side) has a leak where the pipe flange and jug exhaust port meet. It has new metal exhaust gasket, new studs, new exhaust springs. Left side is perfect - tight. Created a gasket and placed it between the flange clamp and the part of the micron pipe head that goes flush with the metal gasket - still leaks. The right, although the studs are tighten down solid, will rock side to side and hit the centre stand(?). Sadly, I might have to put on the stock pipes as soon as I can locate a baffle(s).
- IMG_3260.JPG (123.03 KiB) Viewed 2669 times
Surprise. My neighbour, who owned the bike late 80's & purchased the Microns new, discovered it was the opposite pipe that had the leak and spitting passed the one I thought was effected. Added a washer to the inside stud (where it was spitting) cause the bolt was almost out of thread. I tightened the flange bracked down & it was balanced - perhaps the bracket was bent a bit. The exhaust escaped issue disappeared. 2 cent solution combined with an extra set friendly/knowledgable eyes - can't get any simpler.
I had the same problem with the spring knob hitting my microns. I shortened the knob shaft and re-welded back on the sidestand.
1973 ct70
1974 xr75
1977 rd400
1981 rd350lc
2002 zrx1200
1974 xr75
1977 rd400
1981 rd350lc
2002 zrx1200
Very nice Scott !!!!
