The shim that goes between the brake pad and the piston, was that common to other models as well? Or was it 4L0 only? And are they critical?
I had 4 and can only find one now. Will be calling the shop on Monday and see what they can get for me I guess.
Thanks,
A.
Brake pad shim
Re: Brake pad shim
I dont think I have ever seen one on any of my 350's, No problems with my brakes, I believe its an anti-squeal shim... Im on number 7 at the moment...
Re: Brake pad shim
I had them on the calipers that came off the bike in the fall, and also in the spare set of calipers I got with the bike.
If they're just for anti-squeal, then not as much of an issue. I'll put them together as-is and get replacements and install if I need them.
Thanks,
A.
Thanks,
A.
Re: Brake pad shim
Came with OEM brake pad sets back in the day, not on new stuff. if you really want them you can find OEM NOS sets on ebay etc.
Re: Brake pad shim
Those shims are generally anti-squeel.
Re: Brake pad shim
...and they should be chucked. You don't need them. If your brakes squeal, grab harder.
Re: Brake pad shim
I`m using them on my 85 31K, they are not as big as the brake piston.
I guess they should put more load on the rear side of the pads (in disc rotating direction) to avoid that they have more wear on the front side.
My Bikes:
Yamaha RD500 1985
Yamaha RD350 1985
Yamaha R1 2001
Honda CBR 1000 2006
Yamaha RD500 1985
Yamaha RD350 1985
Yamaha R1 2001
Honda CBR 1000 2006
