LC Motor Coming Together
Its been quite a while (like 3 years) but the spare motor for my LC is finally beginning to come together. Still have a bunch of smaller details to work out but hoping to be able to swap engines later in the summer.
This is what the engine looked like when I bought it at a wrecker 3 some odd years ago. Pretty ratty and the pistons had suffered a 4-corner seizure.
After months of chipping away at it, I just had to see what it will look like so I threw everything together tonight.
It was this pic I was going for but quickly discovered that polishing an LC head is a huge PIA so glossy black paint was a much quicker and easier solution.
Re: LC Motor Coming Together
That is a first class job you have done. I've just finished the engine rebuild on my '82 LC and it certainly doesn't look this tidy, but the engine sure runs well with a new crank, pistons, trans bearings, etc.
Frank Tarpley
1988 TDR250, 1974 GT380, 1968 Cobra, 1984/1987 RZ350, 1983 BMW R80st
Looking good Peter! I like the rockguard or whatever it is on the barrel.
High temp crinkle paint. :)evan_calgary wrote:Looking good Peter! I like the rockguard or whatever it is on the barrel.
- two-stroke-brit
with the RZ stator cover on the LC lump does it hit the frame above were the chain runs.
i had to massage my RZ cover to fit in the LC frame.?
thanks mark
thanks mark
A rd250/350lc left hand engine case bolts straight on and clears that issue up.
Love the Wrinkle paint HD like
Be warned that the VHT stuff takes Months to fully cure.
Until then, it's quite fragile
Test it with yer fingernail .. gently.
LC cover is the way to go.. besides it's not that Crap shiny plastic of the RZ's.
You know about the Sprocket spacings and the 1/8" washer needed to fit the sprocket shaft nut on tightly?
Now you do
Now you do
This motor won't go into a bike for a few months so the paint will have loads of time to cure.Bare wrote:Love the Wrinkle paint HD like
Now you do
Is the 1/8" spacer for when an RZ motor is installed into an LC frame?
Yes Valve Motor into an LC frame. Rear wheel sprocket offset is narrower.
One needs to use the LC engine's Output shaft spacer to line up the sprockets. Easy /peasy.
Problem surfaces when you go to tighten up the sprocket nut and one runs out of
Output shaft thread before the sprocket gets tightened, as it wasn't designed for the short spacer.
One needs an 1/8" spacer between Sprocket and Nut.
Hardware store Washers of a size appropriate to fit the shaft are typically 1/8" thick.
PS; Hopefully those Goofy Airfilters are for storage use only.
Those Suck Power (proven) and a rascal to set up for.
Stock airbox will work a Helluvalot 'better'.
Getting the OE airbox rubbers over the PWK bellmouths is Doable (just) after a bunch of boiling water baths and cursing
Better/easier would be to buy Urethane type boots for a Banshee.. still a bit of a struggle as the LC airbox inlets are Different'.
Just to be clear, the pic of the RZ motor with the polished head is not mine. It was just the pic I used for inspiration when I did mine.
I am using foam UNI filters on my bike. With the 6mm reed spacers, the carbs were a huge PIA to remove when the air of was in place. Hence the move to the UNI filters.
- two-stroke-brit
Hooligan wrote:Just to be clear, the pic of the RZ motor with the polished head is not mine. It was just the pic I used for inspiration when I did mine.
ah ha i fell into your trap.
cheers mark
Ahhhh Wrinkle the Cyl head then.
Black is 'supposed' to be satin black. Not that originality means anything.
But Satin Does look better
My bike has Aprilia mirrors, R1 brakes, aftermarket levers and grips, a whole bunch of SS parts and powdered coated ancillaries. Not really interested in "originality".Bare wrote:Ahhhh Wrinkle the Cyl head then.
Paint wont cure until it gets heated to activate the ceramic in it. I like the look.
Finally building the heavily modified LC Peter?
