ktm thermostat installed to athena setup
Moderators: rztom, 2smoke
two-stroke-brit
#1 Post by two-stroke-brit » Sun Jun 26, 2016 5:41 pm
just thought i would post up some pics of the installed 55 DEG KTM thermostat plumbed in.
i got some "breeze" clamps through amazon. .
solid clamps (no slots) but the edges could be more rounded for my liking .
cheers mark
Re: ktm thermostat installed to athena setup
#2 Post by JonW » Sun Jun 26, 2016 9:07 pm
Good work Mark :)
South_Oz
#3 Post by South_Oz » Mon Jun 27, 2016 6:13 am
Looks like an easy answer to the thermostat problem as well as the water outlet issue.
Dave
RZ 250 85 (Waiting)
RZ 250 85 (Parts)
BMW R1100S 99 (Its Red)
BMW R1200GS (Its BIG)
#4 Post by JonW » Mon Jun 27, 2016 9:07 am
Agreed Dave, I wish id done this with my outlet instead of having it welded, but with the rad solution i had back then it hit the rad hence i had it welded :/
two-stroke-brit
#5 Post by two-stroke-brit » Mon Jun 27, 2016 9:10 am
thanks guys, a vertical outlet would be a better option,but this works without cutting/welding .
no room for a fan though.so i will see how it handles the Texas summer heat, and may have to revisit this.
#6 Post by MK » Mon Jun 27, 2016 11:08 am
If I'd live in Texas there would be no question at all whether a thermostat is needed - the answer is absolutely not.
I rode decades without and the bike has a mileage of 215.000 km.
On a twostroke there is no such thing as too cold. There is no f...ing oil in the pan that needs a min temperature to be pumped everywhere.
Only thing is that for emissions it's better to warm it up, that's why the stock thermostat has some 70 deg C.
In race applications they target 55 deg C plus/minus 5.
As I have a similar KTM part here, I rather worry about the massive flow restriction. My guess is that it'll reduce your system overall cooling performance by maybe 30%.
two-stroke-brit
#7 Post by two-stroke-brit » Mon Jun 27, 2016 11:51 am
Thanks Martin i did look at it when i took it apart to test the thermostat.
but i figured the KTM manages ok.
but if it gets too hot its simple enough to remove
cheers mark
Bare
#8 Post by Bare » Tue Jun 28, 2016 1:25 am
Often a restriction in a cooling flow is Useful. Be it from a designed orifice or a thermostat.
Fast flows can cause damaging hot spots and counterintuitively; overheats.
two-stroke-brit
#9 Post by two-stroke-brit » Tue Jun 28, 2016 8:02 am
Bare wrote:Often a restriction in a cooling flow is Useful. Be it from a designed orifice or a thermostat.
thanks Bare.
Hooligan
#10 Post by Hooligan » Tue Jun 28, 2016 9:13 pm
KTM part no?
two-stroke-brit
#11 Post by two-stroke-brit » Wed Jun 29, 2016 12:59 pm
Hooligan wrote:KTM part no?
i can try and get the number from it tonite.
but it is from a 1999 ktm 250 if that helps.
mark
Hooligan
#12 Post by Hooligan » Wed Jun 29, 2016 3:41 pm
mark
Model? KTM makes so many different bikes the dealer is gonna look at me like I am dumb if all I have is 99 250 to go by.
two-stroke-brit
#13 Post by two-stroke-brit » Wed Jun 29, 2016 8:17 pm
the ebay add said
1999-KTM-125-EXC-200-250-300-380-Radiator-Hoses-Thermostat-54635013144
and it has 113.100 on the side
i just went by the picture
thats all i got.
hope this helps.
mark
#14 Post by JonW » Wed Jun 29, 2016 8:46 pm
Same as what i was going to use on mine, but after a long story of supply let downs etc i bought the Kartelli.
