Need more mid range power
Moderators: rztom, 2smoke
AZRD350LCGUY
#1 Post by AZRD350LCGUY » Fri Oct 28, 2016 4:18 pm
I am rebuilding my RD350LC. Rebuilt crank, new bearings, seals, etc.. What can I do to get more usable power, i.e. the 4000 to 7500 range? I know how to get more power from 7000 to 10000, but that is not where I ride most of the time.
Any suggestions??
1971 Kawasaki F5a Big Horn
2013 NC700X
Bare
Re: Need more mid range power
#2 Post by Bare » Fri Oct 28, 2016 4:45 pm
Fit a PV engine ? :-)
For the LC you can try:
Fiberglass (oem yama ) reeds,
PWK carbs,
Zeel ignition
chalpkin
#3 Post by chalpkin » Fri Oct 28, 2016 4:57 pm
375cc big bore, 56mm bore uses DT175 pistons, made my old LC feel much more torquey in the low to mid-range.
Sent from my SM-G800F using Tapatalk
chalpkin
#4 Post by chalpkin » Fri Oct 28, 2016 4:58 pm
Sorry, that should be 64mm bore!
AZRD350LCGUY
#5 Post by AZRD350LCGUY » Fri Oct 28, 2016 7:19 pm
64 is the stock bore. How does DT175 pistons of the same bore give you anything more??
2013 NC700X
AZRD350LCGUY
#6 Post by AZRD350LCGUY » Fri Oct 28, 2016 7:23 pm
OK, DT175 is a 66mm bore. Which year pistons to use?? Is any modification to the pistons required? Any other information would be helpful.
Thanks.
2013 NC700X
chalpkin
#7 Post by chalpkin » Fri Oct 28, 2016 7:45 pm
My 375cc conversion was done by Stan Stevens (UK). As far as I know the piston skirts have to be trimmed to the same height as the standard one's other than that I'm not sure.
2smoke
Moderator
#8 Post by 2smoke » Fri Oct 28, 2016 9:30 pm
I went to a 520 chain setup and aluminum rear sprocket with a couple extra teeth to help address that area.
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
ghezzi
#9 Post by ghezzi » Sat Oct 29, 2016 3:57 am
58mm stroke x 73mm bore. Mines got plenty of mid-range poke.
#10 Post by JonW » Sat Oct 29, 2016 5:02 am
remove those buck teeth in the inlet part of the cylinder...
Hooligan
#11 Post by Hooligan » Sat Oct 29, 2016 5:37 pm
The cheapest mod is a set of 6mm reed spacers. Totally cured the midrange stumble on my bike.
John
#12 Post by John » Sat Oct 29, 2016 7:39 pm
Yes. The 6mm reed block spacers smooth out the power band.
I also used Boysen 2 stage reeds, raised the exhaust port, mildly opened up the tranfer ports but didn't change the height or shape on the cylinder.
Also installed UFO spacers in the carb slides and adjusted jetting to match.
Wether it's my wishful thinking or not I found that the poweband isn't as abrupt as it used to be and has more get up and go
#13 Post by JonW » Sat Oct 29, 2016 8:24 pm
ahh the 2 stage reads... cue the 'discussion' :D
Bare
#14 Post by Bare » Tue Nov 01, 2016 11:51 pm
Not worth the Candle. Many believe What they choose to.
Logic often has little traction where Brochure Babbles have been effective
Arguably the Yama Crankcase volume is too small (so much for Crankcase stuffing adherents :-)
Reed spacers.. Help.. a little bit.
