It is currently Thu Nov 15, 2018 10:35 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: RZ Fork Swap
PostPosted: Wed Apr 11, 2018 7:10 pm
Here I thought that the Longer (non Waisted) RZ fork tubes were designed to protrude from the triples... to fit the "clip ons' .
No fixing that one.. without swapping for waisted Fork tubes which are shorter Or bodging up a spacer to bolt on regular handlebar clamps above those protruding tubes.
Suppose one could safe Eff it ...and fit the tube ends flush , at the price of messing the front geometry.
PostPosted: Wed Apr 11, 2018 7:35 pm
Yes the later legs are longer for clip ons... thought that was understood. The OP posted that he was using 'early model RZ' forks.
My Projects:
PostPosted: Sat May 26, 2018 9:22 am
I seem to recall someone posting a trick for shortening the later forks by adding a spacer to the stantion inside the fork slider. Saves hacking off the top and is reversible. Called it old school method.
I was thinking of trying this on my hybrid build..if I ever get started.
Would there be an issue with the reduced travel?
PostPosted: Sun May 27, 2018 3:06 am
Just swap out tubes with the earlier model.
PostPosted: Thu Aug 09, 2018 2:43 am
There were two reasons I needed to use the early RZ forks.
1. The need to retain the LC style top of triple clamp bar mounts
2. I have a pair of very expensive NK racing brake caliper conversion plates that fit the narrow bolt spacing of the LC forks. Later model RZ forks use a much wider spacing for the caliper mount bolts.
While later model forks do accept modern Triumph 4-piston calipers, I already have a complete brake setup featuring the NK plates and lovely Yam blue-spot calipers that I wanted to retain and save the cost of going to an entirely different set of brakes.
One issue I did run into that I wasn't aware of is the RZ triple clamps are just slightly wider than the LC triple clamps. Where this becomes and issue is at the wheel and front axle. I had to make custom wheel spacers to fill the space left by the OEM spacers and LC wheels. I also had to slightly modify the LC axle to ensure the nut screwed all the way on to it. Sometimes its nice to have your own home machine shop. :smt003
'81 RD350LC hybrid project bike - in pieces currently
'82 RD350LC in '81 colours - Built by "Solo 2" OEM pipes, UNI filters
'90 RZ350F2 with 31K motor, OEM F2 pipes & airbox
