Front sprocket spacer
Moderators: rztom, 2smoke
Galant2NZ
#1 Post by Galant2NZ » Tue Feb 07, 2017 2:27 am
Hi guys, need a little help with my 81 250LC , can someone tell me the lenght of the spacer that fits between the bearing and front sprocket as I am sure the one I have is to long ,maybe RZ one? As the sprocket sits proud of the spline so the recess in the nut won't go over the spline which also means the lock washer isn't on the spline either.
The bike came as a "kit set" so maybe wrong spacer was put in the bits is what I'm thinking.
2smoke
Moderator
Re: Front sprocket spacer
#2 Post by 2smoke » Tue Feb 07, 2017 11:13 am
I can't give you the exact measurement at the moment, but the rz ypvs one is wider for sure.
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
AZRD350LCGUY
#3 Post by AZRD350LCGUY » Tue Feb 07, 2017 4:57 pm
My engine is on the bench. It's 14mm.
1971 Kawasaki F5a Big Horn
2013 NC700X
Galant2NZ
#4 Post by Galant2NZ » Tue Feb 07, 2017 8:35 pm
Ok cool that makes sense, I will drop mine off to machine shop to be shortened.
Thanks for that
