spax shock
Moderators: rztom, 2smoke
ststrider
spax shock
#1 Post by ststrider » Wed Mar 08, 2017 2:56 pm
Anyone know anything about these shocks? my lc hybrid cam with one,i thought i would have it rebuilt but it doesn't look rebuildable.
chalpkin
Re: spax shock
#2 Post by chalpkin » Wed Mar 08, 2017 3:10 pm
ststrider wrote:Anyone know anything about these shocks? my lc hybrid cam with one,i thought i would have it rebuilt but it doesn't look rebuildable.
I had a spax shock fitted to my '80 RD350LC years ago, it was a a major improvement on the stock shock. Spax are still making suspension components, I'm sure you could contact them and get some help/advice.
Bare
Re: spax shock
#3 Post by Bare » Sat Mar 11, 2017 10:00 pm
Unspoken question being:
Does it actually Need rebuilding?
Is it Leaking?
Has it lost it's pressure
Large chance that it doesn't require work.
Not like Motos get a lot of mileage... certainly not street ridden fragile 2 strokers.
wolfman
Re: spax shock
#4 Post by wolfman » Sun Mar 12, 2017 12:39 am
I know they make shocks for British sports cars.
Emulsion most likely.
Do they have gas fittings on it ?
Tarozzi fork brace
ststrider
Re: spax shock
#5 Post by ststrider » Thu Mar 16, 2017 8:05 am
the shock does not leak but has no pressure,compression dampening is minimal rebound is strong.i replaced it last year with a nitron and was thinking about selling the spax but no fittings for nitrogen.
wolfman
Re: spax shock
#6 Post by wolfman » Thu Mar 16, 2017 11:47 am
Then it's like a condom.
Dispose after use.
Tarozzi fork brace
Bare
Re: spax shock
#7 Post by Bare » Fri Mar 17, 2017 5:53 pm
Rebound control is THE most important function of a shock. Compression is a lesser function
Can't be all that knackered then ?
ststrider
Re: spax shock
#8 Post by ststrider » Sat Mar 18, 2017 10:21 am
the shock still worked fine it was just undersprung for my weight and cranking in more preload makes it harsh.the nitron is silky smooth in comparison as they set them up for your weight even if your a fat bastard.plus it just seems wrong to go year after year without rebuilding the shock ,my dual sport gets freshened up every two years and you notice the difference.
