fork seals LC and early RZ
- two-stroke-brit
My question is are the same part and #.
as i have two spare sets and they are different lengths.
thanks I A. mark
thanks I A. mark
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
Re: fork seals LC and early RZ
Are they not a different ID? I thought the earlier RZ had larger forks thus why it was an upgrade for the LC...Hooligan would know for sure.
Yep. LC forks are 32mm
RZ are 35mm.
Mark: Did you finish your LC with the YPVS motor?
RZ are 35mm.
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
- two-stroke-brit
Hi 2Smoke , well sort of , it runs reasonably well with 350 spec11 pipes cobbled on the athenna motor, but i have some big bore TSA pipes on order that should improve things.2smoke wrote:Yep. LC forks are 32mm
RZ are 35mm.
and a zeel is in its future too.
cheers mark
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
Switch to Yamaha Banshee F'glass reeds.
Cheap and effective improvements.
PS: Zeel is worth as much (more possibly) as pipes, perf adding wise.. just saying
Oohh No PVS' ! Shame that as Zeel PV controller part is worth it's Weight.
LC and RZ forks are entirely different size. I do keep seeing a reference to the dust seals where one is longer? Not really sure what thats about as I've only ever seen one type of dust seal.
The two things I did on my LC motor that made a big difference were CF reeds and 6mm reed block spacers. The spacers entirely get rid of the midrange stumble. My bike will pull cleanly across the 6500 rpm flat spot in 6th gear without any fuss.
'85 FZ750
'85 FZ750
- two-stroke-brit
hey Hooli,do you run the air box or pods.Hooligan wrote:LC and RZ forks are entirely different size. I do keep seeing a reference to the dust seals where one is longer? Not really sure what thats about as I've only ever seen one type of dust seal.
thanks mark
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
I run full foam dual stage Uni pods.
'85 FZ750
'85 FZ750
