fork seals LC and early RZ
Moderators: rztom, 2smoke
two-stroke-brit
#1 Post by two-stroke-brit » Tue May 16, 2017 6:01 pm
My question is are the same part and #.
as i have two spare sets and they are different lengths.
thanks I A. mark
evan_calgary
Re: fork seals LC and early RZ
#2 Post by evan_calgary » Tue May 16, 2017 8:39 pm
Are they not a different ID? I thought the earlier RZ had larger forks thus why it was an upgrade for the LC...Hooligan would know for sure.
2smoke
Moderator
#3 Post by 2smoke » Tue May 16, 2017 9:02 pm
Yep. LC forks are 32mm
RZ are 35mm.
Mark: Did you finish your LC with the YPVS motor?
:smt006
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
two-stroke-brit
#4 Post by two-stroke-brit » Wed May 17, 2017 8:36 am
2smoke wrote:Yep. LC forks are 32mm
RZ are 35mm.
:smt006
Hi 2Smoke , well sort of , it runs reasonably well with 350 spec11 pipes cobbled on the athenna motor, but i have some big bore TSA pipes on order that should improve things.
and a zeel is in its future too.
cheers mark
Bare
#5 Post by Bare » Wed May 17, 2017 7:29 pm
Switch to Yamaha Banshee F'glass reeds.
Cheap and effective improvements.
PS: Zeel is worth as much (more possibly) as pipes, perf adding wise.. just saying
Oohh No PVS' ! Shame that as Zeel PV controller part is worth it's Weight.
Hooligan
#6 Post by Hooligan » Wed May 17, 2017 9:12 pm
LC and RZ forks are entirely different size. I do keep seeing a reference to the dust seals where one is longer? Not really sure what thats about as I've only ever seen one type of dust seal.
The two things I did on my LC motor that made a big difference were CF reeds and 6mm reed block spacers. The spacers entirely get rid of the midrange stumble. My bike will pull cleanly across the 6500 rpm flat spot in 6th gear without any fuss.
two-stroke-brit
#7 Post by two-stroke-brit » Thu May 18, 2017 5:19 pm
Hooligan wrote:LC and RZ forks are entirely different size. I do keep seeing a reference to the dust seals where one is longer? Not really sure what thats about as I've only ever seen one type of dust seal.
hey Hooli,do you run the air box or pods.
thanks mark
Hooligan
#8 Post by Hooligan » Thu May 18, 2017 6:18 pm
I run full foam dual stage Uni pods.
