It is currently Fri Sep 21, 2018 7:02 am
Post new topic Reply to topic  [ 2 posts ]
 Post subject: Glycol In Crank
PostPosted: Mon Nov 27, 2017 9:09 am
When removing the head on my lc I accidently spilled glycol in the cylinders. Do I somehow need to flush it out incase much got down in the crank ?
1973 ct70
1974 xr75
1977 rd400
1981 rd350lc
2002 zrx1200
 Post subject: Re: Glycol In Crank
PostPosted: Tue Nov 28, 2017 2:43 am
Yes. The cheap man's method would be to turn the cases up-side-down. Not recommended. How much fluid are we talking here? If it's just drops? Not so worried. Half a litre or cup, more so worried. I'd then split the cases and clean it out.
Many would say, just drain it and run it. I've seen way worse run through an engine. The good thing? The fluid does not harm the cases. The bad thing? It can do big damage to the bearings if you don't run it soon, this week.
cron
