It is currently Thu Nov 15, 2018 10:53 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Jun 17, 2018 7:31 am
G'day. The lc suffered a soft seize due to a missing reed block gasket, the left cylinder had an air leek leading to seize during run in. Since the cylinders where allready at 66mm i went on the hunt for replacements. I ended up buying a complete 250 engine fitted with 350 barrells, fresh 65mm bore with wiseco pro light pistons, Also had rebuilt oem crank. Today i finnished rebuilding the bike. Now it runs the 250 cases, fresh lc crank, the replacement cylinders with wiseco's and the original 350 transmission and clutch assemble. so it's back on the road. looking at replacing the front forks with rz items and buying a hagon rear shock. otherwise i'm witing for mirrors and indicators then paint the bike. I'm really enjoying the Lc.
yamaha fanatic.
PostPosted: Sun Jun 17, 2018 1:38 pm
Congrats on your perseverance to get back on the road again. No better feeling I imagine from the challanges faced with engine issues. Original mirrors are hens teeth-ish but the aftermarket ones will suffice as I purchased a set (European style) from Yambits. Yet postage was almost the cost of the mirrors then I found originals (lol).
PostPosted: Thu Jul 19, 2018 11:41 pm
Mikes SX has Darned good replicas for only a few $$ . Live 'n learn :-)
PostPosted: Fri Jul 20, 2018 5:49 am
good info thanks Bare. I own a 79 xs750 that would also like some fresh bits from mikes xs. think i'll order some emulators for the rz forks whilst i'm there.
yamaha fanatic.
PostPosted: Fri Jul 20, 2018 5:08 pm
The XS was the 1st shaft driven bike (sliver/blue) I've rode - belong to my brother. Having it pop up from the middle upon acceleration was a unique feeling. Like Jon, the yellow was the most attachive to me. Next is mars bar coloring which is my current paint project (Cnd 82 colours). I think most people recall the yellow speed block image of a Yamie as reto-competitive. Nice job on the XS Graham.
PostPosted: Wed Aug 08, 2018 7:27 am
Been working on the lc. Tank and panels are at the painters, engine is on the bench being rebuilt after painting barrells atc.
About to put the head back on and noticed the copper head gasket that was on the bike has deformed around the combustion chamber. No problem i thought i will order an ome gasket. Yamaha Australia told me gasket 4l0-11181-09 Nla. Found some on the net and borrowed one from a local lc owner till order arrives. This is my first oem lc gasket and unlike the many .7mm thick rz350 gaskets i have bought the lc gasket is 1.3mm thick.
With the .6 copper gasket and head shaved the engine had 1mm squish. The new gaaket will obviously enlargen the squish which is not ideal. The head is nearly shaved down to the edge of the bowl, i can't see how i can back to the 1mm squish without going to copper gasket again. Migbt need to order a slightly thicker one to minimize distortion. Hope to have bime back
On the road by sunday. Image
yamaha fanatic.
PostPosted: Fri Aug 10, 2018 6:39 am
Picked up a bit of candy today. ImageImage
yamaha fanatic.
PostPosted: Fri Aug 10, 2018 7:56 am
Beautiful Graham! That is top notch artistry!
PostPosted: Fri Aug 10, 2018 9:09 am
Like glass... looks amazing.
I feel like shipping my stuff to Oz to be painted...
:smt017
PostPosted: Fri Aug 10, 2018 2:19 pm
Hah! I have a set of grips on mine that look identical to yours. I also have those same slotted disks.
Quote:
Inlet side of Piston skirt has been shortened
This is simply a function of running RZ pistons in LC jugs. Its not a performance mod.
graham heise wrote:
Out on the roadImage
'81 RD350LC hybrid project bike - in pieces currently
'82 RD350LC in '81 colours - Built by "Solo 2" OEM pipes, UNI filters
'90 RZ350F2 with 31K motor, OEM F2 pipes & airbox
PostPosted: Sat Aug 11, 2018 4:07 am
Looks great!
On the plus side, the larger squish will add years to your engine's top end life. Shaved heads on the LCs were like making your engine a time bomb.
PostPosted: Sat Aug 11, 2018 5:38 am
Put the bike back together after a tidy up and paint job. Just need to check over everything and add the fluids. Pretty happy with how it's turned out. Just need to ride it. ImageImageImageImage
yamaha fanatic.
PostPosted: Sat Aug 11, 2018 6:27 am
hondaror wrote:
Looks great!
Can you school me on this rory? How does it make it a time bomb? Won't it make more power?
I thought .9mm is ideal squish? or at least it is on an rz. cooler piston edge, flame burn to the centre and more complete? higher compression? Where does this put undue stress in the engine?
I know you've run plenty of lc's what squish do you run?
I read in the Australian tz forum that guys racing the 250lc's used to lap the cyclinders to the head and run no gasket with .75-.8mm squish.
Can't get my head around a 1,2mm 3 layer oem gasket and having a squish with stock head at nearly 2mm. closer to 1mm would would be better, wouldn't it? I'm here to learn.
yamaha fanatic.
PostPosted: Sat Aug 11, 2018 8:31 pm
hondaror wrote:
Looks great!
:smt001 Yup the 37 hp ..which is what the Factory Reduced Compression setup generated .. during independent Dyno testings 'back then'.
Lawnboy power Outputs.
Theory is lower stresses could potentially let the engine live a lil longer.. Or it may just seem that way.
Although Not much hard evidence of Shorter than LC engine lives evidenced in RZ engines, which were ultimately of Much reduced squish/ increased compressions.. and ~25 Hp More.
PostPosted: Sat Aug 11, 2018 10:15 pm
I concentrated on intake and exhaust for power boost. Many friends shaved heads and blew up. The LC does not like that mod. It was not allowed in production racing in Canada. Made for exciting times, big boost, put poor longevity.
Pipes and pods drastically change the LC, as well, with great results for reliability if you jetted accordingly.
