RD350LC 4LO Build
Re: RD350LC 4LO Build
Anyone have any idea what this block is for, I picked up a Japanese harness so I could use a proper light switch, Everything plugs in except for this mystery block, Its under the tank by the coil, Its in with the switch gear blocks, I'm stumped....
the colors make me think kickstand switch.
the other thing I wonder about is their over-the-limit speed indicator light that is at the bottom of the jap gauge cluster.
Electric diagram for the Canadian LC
Full size here
https://flic.kr/s/aHskpe6WUD" onclick="window.open(this.href);return false;
Full size here
Thanks Guys, Its a block for a headlight relay used on Japanese spec bikes, Have the relay ordered...
Picked up the relays, Fitted them and fiddled with the wires for a few hours and got everything working, Got the clocks on, brakes on and bled, chain and sprockets on, Mudguard and plate holder etc, Head is back from Bill Wilson, Looks class, Nice job Bill, Nice to see you testing out the new mill on the head :)
Porting is roughed in, Have to finish that up, Few more MM here and there need to be removed :P
Bunch of other niggly bits, Progress.. Havent sent the bodywork out yet, Painter is completely backed up, Prima donnas if you ask me.. :P
That rear shock looks like a nice stout piece.
You are doing a first class job.
I am amazed how much work you can do in a short time. Whats your secret?
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
whered you get those caliper brackets? I would like some...
Those are NK Racing caliper brackets from the UK. They are good for mounting Blue Spots .... or in this case Gold Spots. I've got a set on my LC.
Yep, Nigel over at NK racing will sell you a set..
Heads and barrels sanded, masked and painted
Nice work! best use Good rings though, those are Large unsupported holes .. Either OEM Yamas or Wisecos.
wow... i just sold a complete running engine and electrics for less.
More Progress, Heads and barrels on, Reeds in, Clutch cover fitted, Pressure tested, Lost .25 PSI in an hour, I'm happy... Bunch of other little bits and pieces, 2Stroke oil in and pump bled, Radiator and cover fitted and full of coolant, Gearbox oil in, We nearly have a runner. :)
