RD350LC 4LO Build
Moderators: rztom, 2smoke
tacky1
Re: RD350LC 4LO Build
#16 Post by tacky1 » Sat Sep 15, 2018 8:03 pm
LOL, They are the shits, aren't they :)
I did the blue spot on my RZ350, Best upgrade I did by far...
I might just do that with this one, Time to look for a set of adapters :)
Hooligan
#17 Post by Hooligan » Tue Sep 18, 2018 1:49 am
I have the NK Racing adapters on my bike. I just had them anodized black to blend in a bit better.
IF you have even considered upgrading the LC forks to RZ units, get a set of later model lower tubes and mate them to the early model upper tubes. Then a set of Triumph 4-pot calipers will bolt right on, no adapter plate needed.
The late model RZ fork lower tubes have a wider caliper mount spacing.
tacky1
#18 Post by tacky1 » Tue Sep 18, 2018 2:16 am
A little more progress.
Cases and carbs are vapor blasted, Fork lowers footrest hangers fully refinished to factory look, Powder coated clear to protect them.
tacky1
#19 Post by tacky1 » Tue Sep 18, 2018 2:18 am
Hooligan wrote:I have the NK Racing adapters on my bike. I just had them anodized black to blend in a bit better.
Yep, I took your advice, Got in touch with Nigel and have a set on the way, Im going to use Blue Spots, I have a few sets here. :)
tacky1
#20 Post by tacky1 » Tue Sep 18, 2018 2:23 am
Definitely a huge improvement, Thanks Bill, You da man..
kpke
#21 Post by kpke » Tue Sep 18, 2018 11:10 am
Are you for hire for my next build?
Beautiful work Sir!
tacky1 wrote:A little more progress.
Hooligan
#22 Post by Hooligan » Tue Sep 18, 2018 10:56 pm
WOW, the vapour blasting sure turns out nicely.
If you aren't determined to keep the paint OEM, this is what I did with my motor. It is all VHT rattle can. The head is gloss and the barrels are crinkle. It turned out really good IMO.
This was the look I was going for. It was just that the polished head was gonna be a HUGE PIA so I went to the gloss paint as a simpler solution.
tacky1
#23 Post by tacky1 » Wed Sep 19, 2018 2:32 am
That’s a beauty. I’m going to keep mine as close to stock on the outside as I can. I did have a crinkle paint job once and it was a bitch to keep clean. I just spent too much time trying to keep it looking good. So I swore never again :)
Love the carbs. I have a set of stock ones all vapor blasted etc and I have a new set of 30s that came with an RZ I bough. I’m going to run Tyga pipes, V-Force 4 reeds with spacers, ported cylinders and a lot of clean up and I might run the 30s.
Still figuring that one out :)
Hooligan
#24 Post by Hooligan » Thu Sep 20, 2018 3:57 am
Where did you find a set of V-Force reeds to fit LC barrels? I was 't aware they made such a thing.
tacky1
#25 Post by tacky1 » Thu Sep 20, 2018 10:36 am
They don't make them, I'm using banshee reed blocks, Inlets have to be modded for them to fit..
Bare
#26 Post by Bare » Thu Sep 20, 2018 5:44 pm
And just how much metal you have to remove to fit Banshee /Rz reed blocks into an LC cyl. Often modders hit air doing this (although with Care and Precision) it has been done without breaking thru.. V thin margins tho.
#27 Post by JonW » Thu Sep 20, 2018 9:21 pm
you can fit vf3 YZ85 reed blocks to the LC, much easier than using the ypvs versions.
Like bare i wonder just how much hassle you will have what with welding up the thin LC side walls.
tacky1
#28 Post by tacky1 » Thu Sep 20, 2018 10:44 pm
They'll fit, I got them in my last one and no probs, Great blocks..
Hooligan
#29 Post by Hooligan » Fri Sep 21, 2018 3:13 am
Bare wrote:And just how much metal you have to remove to fit Banshee /Rz reed blocks into an LC cyl. Often modders hit air doing this (although with Care and Precision) it has been done without breaking thru.. V thin margins tho.
Quite a lot. I've got a set of cylinders that had it done and the difference is quite big.
Hooligan
#30 Post by Hooligan » Fri Sep 21, 2018 3:15 am
JonW wrote:you can fit vf3 YZ85 reed blocks to the LC, much easier than using the ypvs versions. .
How different is the ZY85 reed block from the LC unit? Does the LC cylinder need to be modified? Do we really think the VF3 reeds are better than a set of HiTech carbon reeds?
Found this document on reed cage modification
http://erlenbachracing.co/reedcages%20mods.htm
