A couple pictures of my project bike**Now finished!!
Moderators: rztom, 2smoke
2smoke
Moderator
#31 Post by 2smoke » Mon Dec 10, 2012 1:36 am
silverstrom wrote:Don't you need to swap everything needed to make the RZ lump work in the RD? Harness, CDI, PV controller, etc? Do you still have thsoe parts, or did they sell on ebay already?
Is there an issue with going over 66 mm with the 4L0 cylinders? Need to rework the head?
I guess it all depends on what you need out of the bike. If it's all stock maybe stick with the stock engine. Resale on the RDLC is climbing fast and original parts will make you more money. If its going to be modified you might as well modify it a lot. You already have the sexy 87RZ and the RZV, so sticking with the 4L0 motor would be my suggestion. Nice to have one of each.
I would have to get another harness and i would go the zeel route if i use the powervalve motor. As far as resale goes, pure stock perfect condition bikes seem to go for the best money.
I think i am leaning towards building a 4LO engine with improvements.
:smt001
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
Moderator
Moderator
Re: .
#32 Post by silverstrom » Mon Dec 10, 2012 3:10 am
2smoke wrote: I think i am leaning towards building a 4LO engine with improvements.
:smt001
That sounds just perfect.
nokturnal
Re: .
#33 Post by nokturnal » Mon Dec 10, 2012 12:36 pm
2smoke wrote:I have finally had some time to take a good look at my 4LO engine and it needs to be completely rebuilt. :smt011
The top end is at 66MM(2mm oversize)and the wiseco pistons/bores are damaged. I havent removed the crank but it doesnt look fresh, the rods are pitted where the small end bearings go etc. So it really needs a full rebuild to know where i stand when i ride it next summer.
I have a complete 1UA rz350 motor here that also needs a full rebuild.
So i am trying to decide if i should keep this bike original or go to the more powerful rz motor. I realize the swap is an easy one, just not sure which engine to go with. What do you guys think?
Any input is appreciated.
:smt017
Gah! That sucks Colin. Scouts honor, I did not know that was inside. Pistons did not look bad from the outside... I guess looks can be deceiving. Sorry the engine is ass. I feel like I was screwed now too actually as the guy said he took it apart, inspected everything, stamp of approval, and put it back together. :smt013 He is pretty well known in the VRRA circle, so this is surprising. If you have pics, I would be interested in having them so I can send them to the guy with a WTF note.
My dad may have other cylinders, but nothing on low bore. He does have some that were on my old bike. PDQ ported, supposedly not ideal as the transfers were not worked much (if at all), but the bike was bloody fast. Think they MAY have a couple bores left.
You have powervalves... stick with the LC engine. Easy to mod for an RZ crank.
Joken
#34 Post by Joken » Mon Dec 10, 2012 9:29 pm
2smoke..I have a space 4LO bottom end..(and more RD350lc parts).if interested..I am just not sure if i am going to use the 4LO motor or RZ motor for my RDLC hybrid project(next year)...but maybe this will help me decide..??? Lete me know if interested
1997 V-Max
1993 V-Max project
1982 RD350LC,,SOLD
1982 RD350LC(gathering parts)
1985 FZ750/1000
1983 RZ350,R1,R6,Z1000,Honda,Aprilia Hybrid..SOLD
etc.........o>'o
2smoke
Moderator
Re: .
#35 Post by 2smoke » Mon Dec 10, 2012 9:57 pm
:smt017
No worries Dana. The price was right. I had to really look in the ports to see any marks and i had a feeling that i should pull the top end. The seizeco pistons look fairly new but they both have several seizure marks. The rings are not pinched. The cylinders are not scored too bad. My guess is too much heat/lack of oil. The bike was on premix, maybe the ratio was nt enough or the cooling system is buggered.
Who is PDQ? Anyway, now i will know the true state of the engine components when my speedo needle passes 200kph this summer
:smt002
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
Joken
#36 Post by Joken » Mon Dec 10, 2012 10:58 pm
PDQ= Pretty Dam Quick...
Buddy of mine just bought a RM250 that had the cylinder done by them...(1983 RM250)
1997 V-Max
1993 V-Max project
1982 RD350LC,,SOLD
1985 FZ750/1000
etc.........o>'o
nokturnal
#37 Post by nokturnal » Tue Dec 11, 2012 12:17 am
to the best of my knowledge, he did not actually run it. literally bought it, took it apart, fixed some cosmetics, and bolted it together since it was "ok". :smt011 truth be told he races 4t kawis...
PDQ was an old speed shop. think they are gone now. Joken is on the money.
2smoke
Moderator
Re: A couple pictures of my project bike
#38 Post by 2smoke » Sat May 21, 2016 11:16 pm
Update! Its finished and on the road!
So many twists and turns in this project.
I ended up keeping it as original as possible.
The only changes I made were a 520 chain+ sprocket upgrade and I used 1983 RZ350 35mm forks and triples.
They worked out great, the steering stops are in the right spot and they use the same bearings as the RD.
The engine is completely rebuilt with a new crank from Yambits, which has worked out great. Its smooth and quiet.
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
2smoke
Moderator
#39 Post by 2smoke » Sat May 21, 2016 11:26 pm
Thanks to everyone who helped with new and used parts!
Yam4l0 for the new horn harness and olive plated screw set, redline junkie, nokturnal, joken, everyone!
My thoughts about the bike so far:
Its a plush soft, street suspension.
Very comfortable seating position, however no wind protection so you really notice the wind.
Powerband is nuts between 7000-9000 but the power goes flat at an indicated 10000rpm
Feels and sounds much different than the RZ350.
I have some aftermarket pipes I will be installing and jetting for later in the summer.
:smt023
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
Evans Ward
#40 Post by Evans Ward » Sun May 22, 2016 12:15 am
Stunning! You did a great job! Smoke on....
steveloomis
Re: A couple pictures of my project bike**Now finished!!
#41 Post by steveloomis » Sun May 22, 2016 12:41 am
Looks great!
South_Oz
#42 Post by South_Oz » Sun May 22, 2016 1:09 am
Very nice. You would have to be happy riding it around.
Dave
RZ 250 85 (Waiting)
RZ 250 85 (Parts)
BMW R1100S 99 (Its Red)
BMW R1200GS (Its BIG)
#43 Post by JonW » Sun May 22, 2016 3:24 am
looks great! well done.
#44 Post by RuZty » Sun May 22, 2016 6:16 am
Nice job Colin, looks great. You'll need a white one now....
2smoke
Moderator
#45 Post by 2smoke » Sun May 22, 2016 10:22 am
RuZty wrote:Nice job Colin, looks great. You'll need a white one now....
Lol. I have already started collecting parts to build a 4L0 special. Color will either be white or "limited version" red.
Wider wheels/modern tires, ported cylinders and other engine mods.
The black bike here is staying the way it is.
Learned a lot from this rebuild. Things to watch out for during the engine rebuild.
This bike was being used as a race bike, and quite a few things needed replacing.
For example the splines on the kicker shaft and shift shaft were toast. The cases needed replacing as the top case was damaged from a chain breaking and the lower had a broken "tab" that the kicker locks into.
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
