LC Hybrids And More !!!
Moderators: rztom, 2smoke
Headcoats
Re: LC Hybrids And More !!!
#106 Post by Headcoats » Thu Mar 30, 2017 12:04 pm
Got frames back from welders and one is a UK frame with log book and the other a German frame with German log book and Nova cert.
Problem is both numbers are correct but just so faint that any powdercoat or paint will pretty much obscure them :(
Would it be unwise to re punch the numbers clearer ?
I guess you would need exactly the right stamps and be very accurate ?
two-stroke-brit
#107 Post by two-stroke-brit » Fri Mar 31, 2017 11:04 am
Headcoats wrote:Got frames back from welders and one is a UK frame with log book and the other a German frame with German log book and Nova cert.
you could mask off the area over numbers
#108 Post by JonW » Fri Mar 31, 2017 7:26 pm
Yes, you'll never match it up. :(
I agree with Mark, mask the numbers before powder.
Headcoats
#109 Post by Headcoats » Sat Apr 01, 2017 11:45 am
Was speaking to someone yesterday and here in the UK, the DVLA will accept a rubbing of the frame number before it's painted or powder coated but like you say it's probably best having it masked off
Headcoats
#110 Post by Headcoats » Mon Apr 10, 2017 7:10 am
[imgoriginal]http://i64.photobucket.com/albums/h174/ ... ay0br3.jpg[/imgoriginal]
looks like I'm starting this again after several years :smt012
Figured I would be dead before I finished it :smt033
#111 Post by JonW » Mon Apr 10, 2017 9:21 am
Interesting... Are the KR1S axles the same size as the RGV suspension?
Headcoats
#112 Post by Headcoats » Mon Apr 10, 2017 9:43 am
The front share the same spindle but the rear on the RGV is quite a bit bigger and had to get made about 5 spacers/sleeves to get it to fit and still have the issue of getting the KR1S rear brake disc working in harmony with the RGV brake hanger !!!
They do both use the same rear brake caliper though
I started this years a go and do have 90% of the parts but still expensive stuff to get finished like getting the bodywork painted
I measured about 9mm offset for the sprockets and can get 5mm off the rear sprocket carrier as I had that done with my red LC and then hopefully will get a 4mm offset front sprocket to line it up
#113 Post by JonW » Mon Apr 10, 2017 7:23 pm
I asked as I have a similar issue with some Honda wheels I was looking to use, ta for the info.
Yes same caliper, so thats helpful, bit of measuring is all you need there.
Paint always seems to cost a small fortune, so i feel your pain.
#114 Post by RuZty » Mon Apr 10, 2017 7:35 pm
Headcoats wrote: I guess you would need exactly the right stamps and be very accurate ?
I have yet to come across commercially available number stamps that match the size and font of the Yamaha ones. Purely out of curiosity of course.
Headcoats
#115 Post by Headcoats » Fri Apr 14, 2017 8:18 am
I think I will leave them alone and get the area masked if I go for paint or powdercoat
Can't find my feckin cush drive for the KR1S wheel so will have to get a replacement then find someone with a lathe
Need a bracket to mount the YPVS servo too
Headcoats
#116 Post by Headcoats » Tue Apr 25, 2017 12:27 pm
Got this to try and fit !
This is the style I'm after over the bulbous RGV mudguard
Headcoats
#117 Post by Headcoats » Thu Apr 27, 2017 12:45 pm
Well the mudguard arrived but has cracks around the two top mounting holes each side which wasn't mentioned FFS :roll:
Have placed the mudguard on the bike though and I think can be made to fit with 2 little brackets :P
Anyone know anything about plastic welding
LC Cnd
#118 Post by LC Cnd » Fri Apr 28, 2017 1:38 am
If your mud guard aka fender is made outta ABS plastic I do have a super cheap solution (literally) that worked on fixing my black LC side panels if interested. It only takes 2 ingredient and a wee bit of time to cook at room temperature. Other form members share the recipe and it was spot on.
Headcoats
#119 Post by Headcoats » Fri Apr 28, 2017 9:56 am
Looks better to me :smt035
#120 Post by JonW » Fri Apr 28, 2017 8:22 pm
Doesnt look too bad at all, whats it off?
