A Couple Of Mine......
Just Joined , Here Are A Couple Of Mine............
lc
Trubrit:
Welcome to the forum!
Wow, i see so many things changed on the white bike!
Which front calipers and master cylinder are you using?
Are the caliper brackets from NK Racing?
Looks like you made the taillight flush. Is that done easily with a 90 degree angle bracket?
Custom swingarm, custom rad, headlight brackets
Billet engine covers, fancy kicker.
What model are the front brake disks off?
Do you have any more pictures?
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
- Evans Ward
Sweeet! I love seeing all of the various bikes (Elsies and RZs).
- steveloomis
Those caliper brackets look like the one's NK did for me to fit gold spot R1 calipers. anxious to try them on the LC with RZ forks.
- aaronmvrider
Re: lc
Thanks For Looking......2smoke wrote:Trubrit:
Fr Calipers Are R6/R1 Bluespots On NK Hangers...
Metmachex Swing Arm Powder Coated..
Master Cylinder & Clutch Perch Are Fazer 600 With Stubby Levers....
Rear Light Is Mounted In A Custom Made Unit (pics below)....
Wheels Are Fully Powder Coated & Then Machined Back .....
& Yes I Have Lots More Pics .......
lc
Trubrit:
Did you make that tail bracket yourself? It looks like a top notch job!
Those guages are pretty cool too.
No corner of the bike is left untouched.
I guess the brake rotors are stock but you had grooves machined in.
The Tie bar for the rear wheel hub looks much better and lighter.
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
was it hard to machine and polish backWheels Are Fully Powder Coated & Then Machined Back .....
i was thinking of masking mine then powder coating
jim
1964 Austin Cooper S 1071cc
1999 Ducati ST 4
1999 Ducati ST 4
Was the ultra water pump kit easy to fit to the LC side cover and oil pump cover
or does the RZ case bolt right up....
I have a spare RZ clutch case
The oil pump cover is nice
Also was the alum intake conversion hard to fit with the LC jugs
thanks
jim
thanks
jim
1999 Ducati ST 4
1999 Ducati ST 4
Awesome work Mate, the bike looks fantastic.
Such as shame all these cool bikes don't come with video's of them during performance tests, although I probably spend enough time roaming around these forums as it is.
76 TZ350(project).
82 RD350LC.
82 SR250.
83 RZ350YPVS.
88 RZ250 YPVS(project).
83 FJ1100.
96 YZF750R(track bike).
99 YZF1000 R1.
00 YZF1000 R1.
72 CB750four.
Lifan 125 Pitbike.
82 RD350LC.
82 SR250.
83 RZ350YPVS.
83 FJ1100.
99 YZF1000 R1.
00 YZF1000 R1.
72 CB750four.
Lifan 125 Pitbike.
