hello, i am frederik, live in belgium and have a cagiva mito rd 350 with an 4lo engine
now is the stator and the cdi damaged,
i'm surching for an "inner rotor" (for example HPI)
who knows of this is the same as an banshee rotor or an ypvs one?
and where can i order one for a good price?
sorry for my bad english
also i have the jim lomas exhaust's on it, and 2 28mm carb's (will chance to 32's)
other ignition
- steveloomis
I suggest you check the boards in UK, much more likely someone will have the stator you need.
Try this Frederik. Located in Germany.
http://www.ebay.de/itm/Yamaha-RD-350-LC ... 9829179296
