Rearset interest
Re: Rearset interest
I used these ebay rod ends. Be forewarned they are China parts so you may die if use them.
4pcs 6mm Female Rod End 2 Right and 2 Left Hand Metric Threaded Joint Bearing
http://www.ebay.com/itm/271036141242?ru ... 26_rdc%3D1
Ordered these rods
FAST FROM THE PAST
205MM AND 225MM
M/F connecting rods
Currently have the 205mm installed. The longer one would be used if I adjust the rear sets back further.
Shifter knuckle is 2003 R6.
Also note the pressure switch at the banjo fitting.
Ordered these rods
FAST FROM THE PAST
205MM AND 225MM
M/F connecting rods
Ken's Garage
Thanks for the helpful post kpke!
I just ordered a set... soo....
(1) Can you (or anyone) point to a source (preferably cheap) for the brembo mcl??
(2) Will the original hose (to caliper) banjo work?
(3) Which raises the question about the pressure switch: Fast/cheap/easy source for that?
(budget severely stretched by buying the 'sets....
Also.... what lube is recommended for the moving parts?
And: Threadlock on any of the screws?
Thanks much in advance...
Greg
Greg
1) http://www.oppracing.com/category/15-br ... -controls/
2) Not sure, mine aren't installed yet, but I don't see why not, these move the master closer to the caliper.
3) See #1.
4) The pivots are sufficiently lubed as delivered, for routine maintenance any EP2 grease would suffice.
5) A drop of blue Loctite on the peg bolt wouldn't hurt, but no need to put it on everything.
3) See #1.
1. I just did an online search for brembo and it'll pop up. Can't remember where I got mine, it wasn't cheap though and if it is? it's a Chinese copy.2bang wrote:Thanks for the helpful post kpke!
Greg
2. Yes but the line itself might be too long and flex in a way that is not functional with travel.
3. The switch is about $30 I think and pretty easy to find.
I think lithium soap based grease is spec'd for all load bearing surfaces.
Loctite all pivot point fasteners and rear set mount bolts, (ask me how I know this) !
Tarozzi fork brace
Tarozzi fork brace
Put a little loctite on all the screws, lost the shifter tip on the first ride
75 RD350
83 RZ350
87 RZ350
03 KX250
78 DT175
83 RZ350
87 RZ350
03 KX250
78 DT175
Thanks much for the replies guys!
Might it have something to do with Morty's experience?wolfman wrote: Loctite all pivot point fasteners and rear set mount bolts, (ask me how I know this) !
Any reason this one wouldn't work?
http://www.oppracing.com/product_displa ... -push-rod/
(Note the different outlet position.) (Might even be preferable) PS11-C rather than B
Greg
Greg
Get whichever one suits your install, you can even fit an integrated reservoir type as used by Aprilia and KTM, but they are a bit more $. Just watch the size, there's a good article linked in this thread about MC sizing and the trade offs.
Yes, saw that.... read the whole thread.. :p
Very good knowledge, the effect of larger dia pistion....
(I might actually find that helpful with the front brakes, but not the rear)
Is there any reason the stock reservior can't be used??
Thanks again,
Greg
Thanks again,
Greg
Greg
They arrived!!! WooHoo!!!!
These are Abso-frikkin-loutely GORGEOUS!!!!
Mathias is GAWD!
WELL worth it!!
These are total bling-bling...
Superbly well done..
Heavy duty but surprisingly light! (they LOOK heavy)
I can't stop looking at them! Even nicer looking "in the flesh".
They were also beyond well packed...... Overkill-packing..
Mathias was a pleasure to deal with, and replied promptly every single time, and very helpful!
Those are my very first impressions...
Now, on to sourcing the odds/ends..
Mathias is GAWD!
WELL worth it!!
Greg
2bang wrote:They arrived!!! WooHoo!!!!
Mathias is GAWD!
WELL worth it!!
Glad you like 'em
Pete
I just looked back at this thread in preparation of ordering a MC and noticed this switch, it is a mechanical switch, not a hydraulic pressure switch and is the wrong type for this application. Hopefully you haven't ordered one yet, you will need an M10x1.0 for a Brembo MC, single banjo style, and 2 copper washers.
ACK!
I ordered it...
But a very long time ago, and the order never arrived!!!
Funny you should mention this, as I'm JUST about to contact OPP about it.
I ordered it just after posting that pic... Going on 3 months now!!!!!
Last email to them went ignored...
One more chance.. then I'm gonna start trashing them everywhere I can.
BTW... can you recommend a specific switch? Maybe even provide a link?
Thnx!
I ordered it...
Thnx!
Greg
Any M10x1.0 pressure switch will work, just make sure you get one for a single banjo. OPP has several on their site, look for the word 'pressure', you can probably find loads of them on eBay too. It does say ships in 3-8 weeks for the one you ordered.
http://www.oppracing.com/product_displa ... gle-banjo/" onclick="window.open(this.href);return false;
http://www.oppracing.com/product_displa ... et-brembo/" onclick="window.open(this.href);return false;
Neither of those are in stock either, so probably a long wait. Use a regular banjo and go without until it comes in.
This should be M10 fine thread, http://www.ebay.ca/itm/Aprilia-Dorsodur ... M8&vxp=mtr" onclick="window.open(this.href);return false;
or just go to your nearest Aprilia dealer and order one, probably have it in days.
KTM used Brembo too, so the thread should be correct, but I've never tried these.
http://www.ebay.ca/itm/NEW-KTM-REAR-BRA ... yg&vxp=mtr" onclick="window.open(this.href);return false;
