Source for brake pad retaining pins for front calipers?
AK Addict
#1 Post by AK Addict » Sun Apr 06, 2014 7:04 pm
I'm in the process of rebuilding the stock brakes and when removing the pads on one of the front calipers the retaining pin stripped. I was able to drill it and get it out with an ez out but now I need a replacement. They're not even shown on the Yamaha fiche, any ideas? 1985 US model
Juicebox
Re: Source for brake pad retaining pins for front calipers?
#2 Post by Juicebox » Thu Apr 10, 2014 1:56 am
Not sure if this is what you're looking for, but there are some at this link. About 3/4 of the way down the page, right under the 28mm carbs.
http://homepage.ntlworld.com/ultimatelccrazy/" onclick="window.open(this.href);return false;
AK Addict
#3 Post by AK Addict » Thu Apr 10, 2014 9:03 pm
Wow a little pricey but at least they has some. Thanks for the link!
AK Addict
#4 Post by AK Addict » Thu May 22, 2014 3:52 pm
After a little research I found they are still available from Yamaha part number 34L-25924-00.
Juicebox
#5 Post by Juicebox » Thu May 22, 2014 5:42 pm
Score.
