New rubber
New rubber
Replaced the humongous 180/120 combination in this bike to see if it alleviates the bus like feeling it has going down the road. New rubber is Bridgestone Bt003rs in 1 160/110 combo. After I finish up cycling 50miles today I'm going for a spin. Heck, if nothing else that skinny rear looks like it belongs there.
- T.RexRacing
Re: New rubber
Probably be a lot more fun in the twisties.
Salvador Dali
Salvador Dali
Re: New rubber
Love to see more pics of your bike.
Re: New rubber
Twisties, that's all we have around here but still have to ride with lot's of restraint. Line of sight is lousy, huge trees & unforgiving guardrails. The tires really helped turn in and I know there more capable than myself. Temp today was quite a bit cooler than it has been and the bike seemed a bit lean a 1/2 throttle. Bought new manifolds and TDR reeds. When I bought the tires I also purchased a new helmet and some boots. track days are just around the corner.
- aaronmvrider
Re: New rubber
stay shiney side up.... be safe on that beauty...
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
1 x rz 500
1 x mv agusta 1000
Re: New rubber
Mr Kane, do you know if that AirTech bodywork will fit on the '86-'90 Canadian RZs?
Re: New rubber
Very nice. Thank you. How about a front shot and a front 3/4 view?
The only issue I think would be the tail piece if anything. I'll give them a shout. Thanks again. Your bike looks great. I hope they can give me a clear windscreen. That's on my wish list.
Re: New rubber
i put a 140/70 bt003 rs on my bike other other day
would say its the biggest tyre you will fit in the stock swing arm / about 5mm of room untill i have chain problems and about 7mm of room in the swinger
but the guy i got it from said it wont last very long . he said alot of guys use them for the track
Re: New rubber
yeah, those are pretty sticky tires. i used to use the R version for track days. don't lean too much if you get caught in the rain...
Re: New rubber
Your bike looks fantastic. I'm going to jump all over that glass, and order a set. That's the look I want and the riding position too. Thanks for the additional pics!!!
Re: New rubber
It's quite comfortable for the type of riding I do.
