Wheel Bearing replacement
- Redline Junkie
I have a set of 86+ rims that need new bearings and seals. The rims didn't have bearings when I got them, so can anyone tell me the bearing number for the front and rear wheel. I need them all and I think I will go to my local bearing shop and buy quality bearings if I had the numbers. Also can the seals be found at a bearing shop or dealer only. Any input would be good.
Thanks Rob
Thanks Rob
1987 RZ350 Stock
1985 RZ350F basket case
1985 RZ500 Stock
1987 RZ350 Stock
1985 RZ500 Stock
Re: Wheel Bearing replacement
I got mine from All Balls, if you use their website, there is a reference chart which covers most models and also cross combinations for head stock bearings. It does not cover the 86 model but they may be able to help you if you email them??
85 RZ350
88 YSR50
82 RD350LC (Current project)
06 Triumph Daytona 675 (track toy)
97 Honda RS125 (race bike #1)
99 Aprilia RS250 (race bike #2)
89 RGV250 VJ21
85 RG500
85 RZ350 Hybrid
86 GSXR750
88 YSR50
89 RGV250 VJ21
85 RG500
85 RZ350 Hybrid
86 GSXR750
6302 for the rear 6301 front
75 RD350
83 RZ350
87 RZ350
03 KX250
78 DT175
83 RZ350
87 RZ350
03 KX250
78 DT175
My bike is a 84 model ans when I changed the bearings there was also a spacer that goes between the bearings on front wheel and rear. You will want to be sure you have those.
1984 Rz350, Wicked Toomey rep pipes, Dynojet kit,Zeel unit,Toomey Y boot filter.
- steveloomis
Emphasis added, you MUST have the spacer that fits between the bearing that the axle goes through. They all clamp together. Without it, there is NO bearing support. I only say this because you said the wheels came without bearings.
'81 RD350LC hybrid w/84 RZ engine. Zeel, Old style Toomeys, Yboot and filter 420 main 22.5 pilot, Air screw 2.5 turns out, DJ needle 2nd from top, Canadian VM26 carbs.
'85 KR/RZ US. Tank is seeping causing a blister in paint.....
- Redline Junkie
Got it, I seen the spacer in the basket but no bearings. I just had the wheels powder coated and getting ready to replace the bearings and seals. Thanks for the help.
Rob
Rob
1987 RZ350 Stock
1985 RZ500 Stock
1987 RZ350 Stock
1985 RZ500 Stock
- steveloomis
Whew, that was close....
Don't forget the one in the sprocket carrier
For updates and pictures from the race track this season follow me on twitter @dcracing_tony
