TDR250 Rear wheel into RD350 YPVS
golgo47
#1 Post by golgo47 » Tue Jun 10, 2014 3:42 pm
I am desperately trying to find a rear spoked donor wheel for an RD350 YPVS. The best I have found so far is a TDR250 rear wheel.
Anyone had any experience with this or have any ideas on how to fit a 17" spoked rear wheel (with disc brake) to a RZ/RD350?
I don't need a fat wheel just the standard 110 rear or maybe 120.
I don't mind making spacers or caliper brackets just looking for something that lines up with the front sprocket fairly well.
Any help appreciated.
Peter A
Re: TDR250 Rear wheel into RD350 YPVS
#2 Post by Peter A » Tue Jun 10, 2014 5:42 pm
Hi,
I have such a wheel in my RD... but I use a FZ600 Swingarm... If you want to do it in the RZ it almost fits - but you need another rear brake...
Look here:
My rear brake is a brembo / Aprillia Mille Mix - but the FZ Swinger is wider than the RD Part!
Peter
golgo47
#3 Post by golgo47 » Wed Jun 11, 2014 3:05 am
Thanks Peter, I have already been admiring your RD for some time now and have wondered what rear wheel you were using, now I know!
How is the alignment between rear and front sprocket? Are you using an offset front sprocket or is this not required?
Greg
Peter A
#4 Post by Peter A » Wed Jun 11, 2014 5:39 pm
Hi,
If You Don t want a bigger tire the original TDR Hub will fit!!
Peter
golgo47
#5 Post by golgo47 » Thu Jun 12, 2014 3:04 am
Awesome! Thanks for confirming, now I just need to track down those rare TDR wheels...
waltmil
#6 Post by waltmil » Thu Jun 12, 2014 8:18 pm
Peter, I'm sure you already know this but you have a beautiful motorcycle!
Peter A
#7 Post by Peter A » Sun Jun 15, 2014 11:20 am
waltmil wrote:Peter, I'm sure you already know this but you have a beautiful motorcycle!
... yes I Know!!! But still working on a few Details of the bike...
Peter
Bare
#8 Post by Bare » Fri Jun 20, 2014 1:35 pm
Magnificent Bike, Peter. Well done.
Noticed that the fork tubes have their Air valves sticking up. I find those unnecessarily frightening
Is there a way to remove them.. sure looks like a horrible injury source.
Surprised about that.. in Germany :-)
