I want to replace the two joint seals on a 1985 RZ350N rear brake caliper. I already have all the OEM parts and seals. I found power house automotive in UK seems to have some that look like a good match. Anyone have a source closer?
Splitting the rear brake caliper 85 RZ350N
1985 RZ350N
Original owner
Original owner
Re: Splitting the rear brake caliper 85 RZ350N
Hey Jim,
In Illinois too. Split mine 2 years ago and replaced them with these from mc master Carr. Double-Seal Viton[REGISTERED SIGN] Fluoroelastomer O-Ring, AS568A Dash Number 110
No problems at all. Order today and have them Thursday.
Hope it helps
Sent from my iPad using Tapatalk HD
Hope it helps
1984 RZ 350
Heck. Pm me your address and I will send you some in the mail
1984 RZ 350
- steveloomis
Is this a great forum or what? I'm sure he had to order a minimum order. I got some for my Toomey Replica spigots that the header pipe slips into. Had to order 25 minimum. If anyone needs a couple of those, let me know...
'81 RD350LC hybrid w/84 RZ engine. Zeel, Old style Toomeys, Yboot and filter 420 main 22.5 pilot, Air screw 2.5 turns out, DJ needle 2nd from top, Canadian VM26 carbs.
'85 KR/RZ US. Tank is seeping causing a blister in paint.....
Crnadvm – thanks for the quick reply and generous offer. I repair hydraulic components for a living and just happen to have a few of these in the shop. Steve this is a fantastic forum. There is a huge amount of information you can search from and if you can’t find it post a question. This is a perfect place for guys like me who can do the work but don’t have the “insider” information an experienced mechanic or fanatic has.
1985 RZ350N
Original owner
Original owner
Do you mean the part that bolts to the cylinder? I have some but they are not in the best of shape.... PM me some details if you don't mind!steveloomis wrote:Is this a great forum or what? I'm sure he had to order a minimum order. I got some for my Toomey Replica spigots that the header pipe slips into. Had to order 25 minimum. If anyone needs a couple of those, let me know...
85 RZ350
88 YSR50
82 RD350LC (Current project)
06 Triumph Daytona 675 (track toy)
97 Honda RS125 (race bike #1)
99 Aprilia RS250 (race bike #2)
89 RGV250 VJ21
85 RG500
85 RZ350 Hybrid
86 GSXR750
88 YSR50
89 RGV250 VJ21
85 RG500
85 RZ350 Hybrid
86 GSXR750
I just installed a set in a project I'm working on.
Hope this helps, they are not the squared off rings but they work.
AS568A-110 o-rings from mc mastercarr.
Or if you know someone in aviation.
AS3209-110 or ms 28775-110
Speed
Speed
