Hello all,
I was hoping for a bit of info.
I want to use the FZR stem and I have access to a lathe so I've already lowered the upper bearing step.
My question is:
Does anyone know for sure the die size on the threads for the stem lock nuts and the top nut?
To my best measurements it appears to be a 25mm X1.0 and a 22mm x1.0.
Thanks for any advice.
ETA: Nevermind. I set up my lathe at home and picked up the other threads.
Fzr600 RZ front end swap.
