Steering Damper installed
1990 RZ350
-Spec ll exhaust
-VFORCE 3 reeds
-Chariot billet intakes
-TM28 Mikuni flat slides
-UNI pods
-Mild port work
2000 Banshee
-421cc cub
-Vito's crank
-Shearer SB
-VFORCE 3 reeds
-TM34 Mikuni flat slides
-UNI pods
-Shearer slingshot lockup clutch
2009 Kodiak 450
-Big Gun Eco exhaust
-AMR stage 3 rev box
-UNI filter
-EPI clutch kit
-1mm shim
-Mudlite XL's
My toys: 1999 Banshee (4mm stroker 5mm long rod) with lots of other goodies.
1990 RZ350 all stock except K&N Pods.
1998 Blaster (girlfriends machine i built for her)
- Redline Junkie
Re: Steering Damper installed
Nice damper, where did you get itÉ
Rob
Rob
1987 RZ350 Stock
1985 RZ350F basket case
1985 RZ500 Stock
1987 RZ350 Stock
1985 RZ500 Stock
Looks like a Shindy with an Ohlins sticker. They are nice units
- aaronmvrider
too short for full lock ????
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
1 x rz 500
1 x mv agusta 1000
Yeah that was the sticker on it when I got it, it's not an Ohlins damper.
It's just enough for full lock.
1990 RZ350
-Spec ll exhaust
-VFORCE 3 reeds
-UNI pods
-Mild port work
2000 Banshee
-421cc cub
-Vito's crank
-Shearer SB
-VFORCE 3 reeds
-UNI pods
2009 Kodiak 450
-UNI filter
-EPI clutch kit
-1mm shim
-Mudlite XL's
1990 RZ350
-Spec ll exhaust
-VFORCE 3 reeds
-UNI pods
-Mild port work
2000 Banshee
-421cc cub
-Vito's crank
-Shearer SB
-VFORCE 3 reeds
-UNI pods
2009 Kodiak 450
-UNI filter
-EPI clutch kit
-1mm shim
-Mudlite XL's
- Redline Junkie
Is 140mm stroke enough for an RZ350 mounted is the same manner as pictured?
1987 RZ350 Stock
1985 RZ500 Stock
1987 RZ350 Stock
1985 RZ500 Stock
- aaronmvrider
?? pretty sure it needs 180-190...
1 x rz 500
1 x mv agusta 1000
1 x rz 500
1 x mv agusta 1000
I'll lock but I can't get a full turn to the right, which is fine I get like 1/2 a turn
1990 RZ350
-Spec ll exhaust
-VFORCE 3 reeds
-UNI pods
-Mild port work
2000 Banshee
-421cc cub
-Vito's crank
-Shearer SB
-VFORCE 3 reeds
-UNI pods
2009 Kodiak 450
-UNI filter
-EPI clutch kit
-1mm shim
-Mudlite XL's
1990 RZ350
-Spec ll exhaust
-VFORCE 3 reeds
-UNI pods
-Mild port work
2000 Banshee
-421cc cub
-Vito's crank
-Shearer SB
-VFORCE 3 reeds
-UNI pods
2009 Kodiak 450
-UNI filter
-EPI clutch kit
-1mm shim
-Mudlite XL's
I'll measure the stroke
1990 RZ350
-Spec ll exhaust
-VFORCE 3 reeds
-UNI pods
-Mild port work
2000 Banshee
-421cc cub
-Vito's crank
-Shearer SB
-VFORCE 3 reeds
-UNI pods
2009 Kodiak 450
-UNI filter
-EPI clutch kit
-1mm shim
-Mudlite XL's
1990 RZ350
-Spec ll exhaust
-VFORCE 3 reeds
-UNI pods
-Mild port work
2000 Banshee
-421cc cub
-Vito's crank
-Shearer SB
-VFORCE 3 reeds
-UNI pods
2009 Kodiak 450
-UNI filter
-EPI clutch kit
-1mm shim
-Mudlite XL's
- Redline Junkie
Ok great. Thanks
1987 RZ350 Stock
1985 RZ500 Stock
1987 RZ350 Stock
1985 RZ500 Stock
i have 120mm stroke damper, the biggest daytona sell and it has just enough to get full lock both sides . no matter how you mount it
it has 5mm spare each side
The one I installed is 100mm stroke. Positioned right I can lock the handle bars to the left but only get 1/2 turn to the right but I'm not worried about it.
1990 RZ350
-Spec ll exhaust
-VFORCE 3 reeds
-UNI pods
-Mild port work
2000 Banshee
-421cc cub
-Vito's crank
-Shearer SB
-VFORCE 3 reeds
-UNI pods
2009 Kodiak 450
-UNI filter
-EPI clutch kit
-1mm shim
-Mudlite XL's
1990 RZ350
-Spec ll exhaust
-VFORCE 3 reeds
-UNI pods
-Mild port work
2000 Banshee
-421cc cub
-Vito's crank
-Shearer SB
-VFORCE 3 reeds
-UNI pods
2009 Kodiak 450
-UNI filter
-EPI clutch kit
-1mm shim
-Mudlite XL's
1990 RZ350
-Spec ll exhaust
-VFORCE 3 reeds
-UNI pods
-Mild port work
2000 Banshee
-421cc cub
-Vito's crank
-Shearer SB
-VFORCE 3 reeds
-UNI pods
2009 Kodiak 450
-UNI filter
-EPI clutch kit
-1mm shim
-Mudlite XL's
1990 RZ350
-Spec ll exhaust
-VFORCE 3 reeds
-UNI pods
-Mild port work
2000 Banshee
-421cc cub
-Vito's crank
-Shearer SB
-VFORCE 3 reeds
-UNI pods
2009 Kodiak 450
-UNI filter
-EPI clutch kit
-1mm shim
-Mudlite XL's
Part of the damper's purpose is to limit side to side movement in order to retard side to side slap situations. You should not even consider one if you mind giving up turning radius. This is a tool to enhance high speed performance, not an around town mod. High speed requires very little turning input.
