tarozzi rearsets on a LC350
Hi guy's,
Can anyone give advice (pics would be good) on how they got around the kickstart hitting the toe piece on the tarozzi's please?
I have an 350 4L0 with RGV VJ22 arm.
Regards
Vin
Regards
Vin
Re: tarozzi rearsets on a LC350
vin hi ,I have a set on my lc my solution is /was crude I cut the end of the foot peg at an angle.i would imagine you foot rest hangers have been spaced out from the frame to give the pipes clearance from the swing arm. I will take some pictures for you ,but recently I have been having trouble posting pictures.
- aaronmvrider
i cut a recess into the dowel pin area behind the foot post so the brake pedal flips up
here is the sock photo Jon...
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
1 x rz 500
1 x mv agusta 1000
- aaronmvrider
pedal only goes to the vertical and is in the normal position to apply pressure to the brakes... it has never flipped up on me when riding as it is tensioned with the threaded ring..
1 x rz 500
1 x mv agusta 1000
1 x rz 500
1 x mv agusta 1000
Wahoo the famous photo returns!
Thanks for the feedback guys.
aaronmvrider , Any chance of pic's of the modified lever please mate?
- aaronmvrider
original piece on left and altered piece on right...
i am not sure i removed that much material out of the part... i only removed to the 2nd hole not 3 as pictured as i didnt want it flipping right back.... from memory
1 x rz 500
1 x mv agusta 1000
1 x rz 500
1 x mv agusta 1000
- aaronmvrider
any progress.....
1 x rz 500
1 x mv agusta 1000
1 x rz 500
1 x mv agusta 1000
No not yet mate........... I need to get my finger out!!....lolaaronmvrider wrote:any progress.....
worked a treat thanks mateaaronmvrider wrote:any progress.....
