Side stand spring tips and tricks help please
kpke
#1 Post by kpke » Sun Dec 07, 2014 12:40 pm
I am getting old and weak [smilie=wheelchair.gif]
Does anyone have any tips on stretching the side stand spring?
There must be some sort of a leverage trick to getting this thing attached. :smt100
Thanks.
bitzz
Re: Side stand spring tips and tricks help please
#2 Post by bitzz » Sun Dec 07, 2014 3:42 pm
Hold the spring securely, in a vise, bend the spring, ram coins/washers into the coils. Repeat till it is the right length. Install. Pull the stand down, all the washers fall off.
waltmil
#3 Post by waltmil » Sun Dec 07, 2014 6:15 pm
What works for me, remove the pivot bolt, attach the spring then use the sidestand as a lever to aline the bolt holes then put the bolt in.
#4 Post by JonW » Sun Dec 07, 2014 6:41 pm
Ive always done what Walt suggests... but bitzz's idea is genius.
kpke
#5 Post by kpke » Sun Dec 07, 2014 11:34 pm
JonW wrote: but bitzz's idea is genius.
Agreed. :smt023 :smt023 :smt023
And I did just that. But amazingly after stacking every coil with pennies I came up about 1/4 inch short. :smt022
I taped the pennies as I put them in to keep them from falling out.
For your amusement :smt043
In the end I did it the Walt/Jon way. I am pretty sure that's what I did in the past.
Thanks for your help!!! :smt008
#6 Post by RuZty » Mon Dec 08, 2014 7:18 am
Yep, what Walt said, works every time.
Zedixe13
#7 Post by Zedixe13 » Tue Dec 09, 2014 10:26 pm
And the stack of pennies will increase the value of your bike .
expat
#8 Post by expat » Sun Dec 14, 2014 4:35 pm
Use a Phillips screwdriver, hook the spring onto the shank, place the vee at the tip of the driver against the boss the spring clips onto and lever it into place. Use a rag to cover the spring and catch it if it slips. Oh yeah, and mind your fingers!
Never fails for me!
85 RZ350
88 YSR50
82 RD350LC (Current project)
97 Honda RS125 (race bike #1)
89 RGV250 VJ21
85 RG500
85 RZ350 Hybrid
86 GSXR750
#9 Post by hondaror » Fri Dec 26, 2014 8:44 pm
I use vise grips to stretch it on.
