rz brake ?
- two-stroke-brit
rz brake ?
being a RD fan i have only a passing knowledge of the RZ , so my question is did any of the later models have twin piston caliper brakes.
T I A Mark
T I A Mark
Re: rz brake ?
yes 85-on ROW, USA never got em.
- two-stroke-brit
Re: rz brake ?
Thanks jon i feel a little ebay search comming on .
thinking of swapping out the front end for that model if i can also make the LC wheel work with them.
more thinking aloud though really.
cheers mark
cheers mark
Re: rz brake ?
The easier way would be to use some caliper adapter brackets with your forks.
But you could pick up early rz350 upper +lower triple trees then do this:
http://www.rzrd500.com/phpBB3/viewtopic.php?f=2&t=12559
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
Re: rz brake ?
the fork swap would be pretty easy I think... the axle is the same, the brakes might be interesting as i bet they are spaced a little further out on the RZ, but its not impossible...
Re: rz brake ?
I believe the early RZs are the same as the RD LC for caliper mount spacing, but the later F2 would need carriers as mentioned. Get your hands on an F2 front end or buy the lower legs and calipers from the F2 for the earlier RZ forks.
Re: rz brake ?
The best way to work out what you need is to try it really, it cant be that hard, at least the axle is the same on the early RZ forks to the LC, as is the front wheel spacer and the speedo drive, Ive not checked the 85-on front end parts books, but they are out there Mark if you get a chance (F2 is on xaviers site?), just compare to partzilla's parts listing and you will know. (report back too pls!) :)
Re: rz brake ?
Steve, offroad, just did a fork swapping.
- two-stroke-brit
Re: rz brake ?
2smoke wrote:The easier way would be to use some caliper adapter brackets with your forks.
i read this earlier and its what got me thinking.
the only wrinkle is i would want to keep the LC wheel .
but i am fairly sure it would only be a matter of making up some spacer plates for the rotors,
a local buddy has 2 rzs but not sure what year ( not running),
he is going to do some painting for me , so beer in hand i will be snouting through his packed garage
cheers all Mark
Re: rz brake ?
Just ask the man who has all the parts!
Re: rz brake ?
Actually the 85's were longer than the 86's from what ive read, tho i didnt know that when I had a set of 86's here so didnt compare them. seems there are some differences between the N and F models or something...
Mark, you can fit R1 blue spots to the LC with spacers that are sold by NK and I think that TDR was going to make some more locally to you as well. But if you wanted all 'period yam', then swapping the forks and doing what we discussed earlier in this thread is the way. The R1 brakes will stop you much quicker but not look 'period' of course.
bear i mind that if you fit the later forks and get that setup working but then decide you want more braking that you can fit the Triumph calipers as well, they really work well on these light bikes.
http://2smoked.com/Yamaha_RD_%26_RZ_upg ... ipers.html" onclick="window.open(this.href);return false;
- steveloomis
Re: rz brake ?
I have both NK racing caliper adapters for the RZ and LC and 2 sets of TDR's adapters. The TDR adapters are first rate, NK is rather sloppily made.
Re: rz brake ?
On my LC I have mounted 83 RZ350 forks with the LC wheel and rotors. Its nice because the LC headlight brackets fit on the tapered section of the upper tubes. The caliper offset is the same as the RZ. I am using the side mounted LC fender. The top mounted late model RZ fender just doesn't look right to me on a LC so I wont be using late model RZ fork lowers.two-stroke-brit wrote:2smoke wrote:The easier way would be to use some caliper adapter brackets with your forks.
cheers all Mark
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
- two-stroke-brit
Re: rz brake ?
thanks guys , lots of great info there.
cheers Mark
cheers Mark
