RZ350 Steering head dust seal
Does anyone know if the dust seal on the lower end of a 1987 RZ350 steering head goes on taper side up (against the ball race) or down (against the under bracket)? The non tapered side of the dust seal has a groove.
Re: RZ350 Steering head dust seal
If you set the lower bearing into the race in the frame and put the seal against it you might find it only actually seals one way.
From what I can see either way looks to have merit. Such a simple thing to get stumped on. lol
Can you post a pic? I had a look and can't see anything with it installed. IIRC, it was essentially a flat disk with a rubber lip around the edge. The rubber lip went more to one side of the disc than the other, that side goes up, away from the lower triple. Then again I could be remembering one from an R6 stem, but they should be similar.
Thanks for the help. I've been informed that the taper side goes up. I'd post a pic if I could figure out how :)
Thats how Ive always seen them on bikes with their original bearings Hutcha.
- Moderator
These are the pics Don sent me yesterday. I confirmed that this is the correct installation. You can see why it will only work this way.
That helps, yes, lip always goes to the environment side so stuff can't push past it. The image in my mind was not that seal, possibly an All Balls one I bought for a conversion. Thanks John!
