RZ350 Steering head dust seal
hutcha107
#1 Post by hutcha107 » Wed Apr 22, 2015 1:17 pm
Does anyone know if the dust seal on the lower end of a 1987 RZ350 steering head goes on taper side up (against the ball race) or down (against the under bracket)? The non tapered side of the dust seal has a groove.
Re: RZ350 Steering head dust seal
#2 Post by RuZty » Wed Apr 22, 2015 5:00 pm
If you set the lower bearing into the race in the frame and put the seal against it you might find it only actually seals one way.
hutcha107
#3 Post by hutcha107 » Wed Apr 22, 2015 7:32 pm
From what I can see either way looks to have merit. Such a simple thing to get stumped on. lol
#4 Post by RuZty » Thu Apr 23, 2015 5:48 am
Can you post a pic? I had a look and can't see anything with it installed. IIRC, it was essentially a flat disk with a rubber lip around the edge. The rubber lip went more to one side of the disc than the other, that side goes up, away from the lower triple. Then again I could be remembering one from an R6 stem, but they should be similar.
hutcha107
#5 Post by hutcha107 » Thu Apr 23, 2015 10:25 am
Thanks for the help. I've been informed that the taper side goes up. I'd post a pic if I could figure out how :)
#6 Post by JonW » Thu Apr 23, 2015 8:41 pm
Thats how Ive always seen them on bikes with their original bearings Hutcha.
Moderator
Moderator
#7 Post by silverstrom » Thu Apr 23, 2015 9:13 pm
These are the pics Don sent me yesterday. I confirmed that this is the correct installation. You can see why it will only work this way.
#8 Post by RuZty » Thu Apr 23, 2015 9:53 pm
That helps, yes, lip always goes to the environment side so stuff can't push past it. The image in my mind was not that seal, possibly an All Balls one I bought for a conversion. Thanks John!
