Speaking of Forks .. rubber boots?
Bare
#1 Post by Bare » Mon Apr 27, 2015 2:02 pm
Considering fitting rubber boots to my RZ forks.
I like the look of Old Skool bellows and the protection aspect probably isn't a bad idea either
Any suggestions as to where to buy such and perhaps even which ones would fit decently ?
Re: Speaking of Forks .. rubber boots?
#2 Post by JonW » Mon Apr 27, 2015 8:44 pm
Try and find something OEM would be my advice, there are a bunch of aftermarket ones out there but i reckon they would die pretty quickly :/
Moderator
Moderator
#3 Post by silverstrom » Mon Apr 27, 2015 11:55 pm
You mean fork gaiters? It's great way to trap dust and moisture and rot your fork tubes. Save yourself the trouble and don't do it.
Hooligan
#4 Post by Hooligan » Thu May 07, 2015 2:32 am
The Yamaha TTR230 has rubber boots on the forks. Those might be close to the right size.
aaronmvrider
#5 Post by aaronmvrider » Thu May 07, 2015 4:19 am
surely you dont mean this style...
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
Bare
#6 Post by Bare » Mon May 11, 2015 8:56 pm
Thanx for the inputs..
No.. those rubbers fitted to that pore RZ seem as a wee bit oversized.
Unlikely that (my) boots would be fitted and entirely forgotten, for the neglect required to mess up the fork tubes.
Pesky bike gets wayyy too much fiddly attention for that.
aaronmvrider
#7 Post by aaronmvrider » Thu May 14, 2015 4:14 am
enlighten me ... what rubbers are you thinking...
1 x rz 500
1 x mv agusta 1000
Amboyy
#8 Post by Amboyy » Mon May 25, 2015 10:44 pm
It's a good way to prevent offspring project bikes from popping up, but they gotta fit tight. I can see all sorts of RZ's springing up in the same garage as that forlorn Z with the loose blue gaitors...
L.B
#9 Post by L.B » Mon May 25, 2015 11:34 pm
What about just front facing sliders,like the usd's use.
Mark just made a set for his LC out of pvc pipe.
http://www.rzrd500.com/phpBB3/viewtopic ... 15&t=12791" onclick="window.open(this.href);return false;
