i don't know what "feely" would translate to .
but the opposite would be "squirley"
11/12mm front brake master cylinder
- two-stroke-brit
Re: 11/12mm front brake master cylinder
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
well, the brembo dictionary says the opposite of feely is wooden.....
well just thought I'd like to report. The brakes feel (literally) much better. I was a little nervous entering the first corner, 90 degree right at ~95MPH, but it all turned out well. I even managed to momentarily lock the front wheel, so clearly the 11mm master cylinder has the power to work a single blue spot caliper. Phew
