Tz type 4pot calipers for rz350
I found these, http://japan.webike.net/products/21799025.html browsing the web !
Anyone know anything about these as they seem to be 83mm ?
Tarozzi fork brace
Tarozzi fork brace
Re: Tz type 4pot calipers for rz350
Off the rgv250 so should be good. Dont know if they are 83mm tho....
They say 83mm pitch.
I'd like to find out more about these.
Tarozzi fork brace
Tarozzi fork brace
Those fit the Canadian/euro rz350 forks only...86-90
They came on the early gsxrs. Around 89 I believe.
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
Yup, just discovered mine are 40mm spacing dammit, musta forgot that tidbit !
Tarozzi fork brace
Tarozzi fork brace
Now, these, http://www.cmsnl.com/products/cnc-calip ... aMKjnBHaK2 are 40mm maybe they'll work, although it does say fits Daytona
Tarozzi fork brace
Tarozzi fork brace
Grab some of these:
http://www.rzrd500.com/phpBB3/viewtopic.php?f=7&t=12092
R1/R6 calipers are light and powerful and so many choices on aftermarket pads...
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
Thanks but I don't want the adapters they look a bit dodgy to me.
Tarozzi fork brace
Tarozzi fork brace
They are the same as the Triumphs basically, just a slightly different unit, both by Nissin and both fit the later forks.
http://2smoked.com/Yamaha_RD_%26_RZ_upg ... ipers.html" onclick="window.open(this.href);return false;
- T.RexRacing
The brackets for the R1/6 calipers are fine. I run a set made by a forum member. Running a Brembo M/C from an Aprilia.
Salvador Dali
Salvador Dali
So how are the R1 calipers compared to stock?
Mind you I'm running a 13mm bore Nissin master cylinder with braided lines and sintered pads. So it's as good as stock stuff can get.
Thanks.
Thanks.
- T.RexRacing
More power,better feel-just all around better and I'm still using ancient rubber lines. Didn't use stainless to see just how strong they were. Like others I had visions of the 35mm fork tweaking. But the limit is traction and it's the same tire it was with stock.
Don't think I'd install Yamaha monoblocks with a 13MM m/c. I'm running a 19MM m/c. The pressure will be higher but it'll take a lot of lever travel to be effective.
Salvador Dali
Salvador Dali
The blue spots are a great caliper. It's my go to on project bikes. I search for FZ6 calipers, same caliper as the R1, half the price.
On my XV920R. 475 lbs wet, 37mm legs. I use an FZ1 MC. Works great.
Cheers!
Pete
Pete
- two-stroke-brit
hey hellgate that caliper adapter looks so much better latticed/webbed out (is that a word?).
who makes them?
who makes them?
I found the base drawing on the XS650 Forum and a buddy of mine made them for me. We had to tweak it a little to get the pads to align with the rotor correctly. He designed the webbing and added bevels to each edge.
The front wheel should look familiar to F2 and SRX6 owners.
Cheers!
Pete
Pete
