Way to identify suspension components
I just recently bought a RZ350 that has newer suspension and 17" wheels. I am trying to identify what parts were used. The rear swingarm looks to be aluminum and similar to an FZ or FZR swinger. I'm trying to figure out what clip ons were used and if I could get some taller ones.
85 RZ350-Messed up wiring
- two-stroke-brit
Re: Way to identify suspension components
looks interesting whats the deal with the headlight/fairing ?
is it loosely offered up for fitting .
cheers mark
cheers mark
The fairing mounts are missing the little plastic shims to hold it up. I need to talk to someone about getting those pieces.
Aren't those stock forks and triples? Also looks like you have mixed a full fairing F2 with the gauges from the earlier F1?
The front suspension is from the FZR600 for sure, I know because I have one.
90 RZ350 Track bike.
86 RZ350 Stock daily runner.
84 DT200
84 RZ500
84 DT200
84 RZ500
Did the FZR600 ever come with a 17" rear wheel?
No the FZR 600 rear wheel was 18" but can fit a wider tyre size and better rubber than stock.
84 DT200
84 RZ500
84 DT200
84 RZ500
Is that bad it isn't a 17" wheel?
No, not bad at all, just more tire choice with a 17 inch. Because almost all the new bikes run 17`s.
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
