Amount of oil in each front fork? 1992 Yamaha DT50R.
sedsberg
#1 Post by sedsberg » Sat Aug 01, 2015 12:52 pm
Does anyone know how much oil to add to the front forks on this bike?
1990 RD350 F2 1WT
mkane
Re: Amount of oil in each front fork? 1992 Yamaha DT50R.
#2 Post by mkane » Sat Aug 01, 2015 8:11 pm
Take springs out and collapse suspension. Put in enough to cover damper rod would be a good starting point.
sedsberg
#3 Post by sedsberg » Sun Aug 02, 2015 7:40 am
Thanks!
1990 RD350 F2 1WT
Off Road
#4 Post by Off Road » Sun Aug 02, 2015 7:23 pm
According to the Motul oil adviser, each fork leg needs 0.22 liters of 10W oil.
https://www.motul.com/gb/en/products/recommendation" onclick="window.open(this.href);return false;
sedsberg
#5 Post by sedsberg » Sun Aug 02, 2015 8:40 pm
I'm a bit sceptical to that advisor. It shows totally wrong amount for the gear oil.
1990 RD350 F2 1WT
#6 Post by JonW » Sun Aug 02, 2015 9:16 pm
I am amazed anyone here knows this for a DT50R... I tried to buy one (an MX model) once back in 1991, it was an early 80s 'thing' and was in a scrapyard in the uk... that was the last (and worst) DT50 Ive seen... :/
Joking aside tho, you may well be better to locate a forum for mopeds, I thought there was a few northern Eu (Sweden based?) forums for small bikes, failing that the Dutch had a lot of Brommers back in the day... I had MT5 and MB50 and TS50 back in the mid 80s when i was a lad and a friend had a new (83) DT, it was wonderful compared to our old bikes... Anyway... just trying to help, not scare you off.
sedsberg
#7 Post by sedsberg » Mon Aug 03, 2015 11:37 am
I've had two of these before so I remember most of the tech stuff. Including everything that fails on these. :P Just forgot about the fork oil since I've only done an overhaul once on this model.
1990 RD350 F2 1WT
