Bad Clutch Shudder
- RZResurection
Bad Clutch Shudder
I have some rude clutch shudder when I launch hard.
I rebuilt the clutch and basket last winter. Brand new FZ600/1000 fibers and new dampers (urethane pucks)
I have a 180 back tire with a 39T sprocket. My feeling is that I need some more torque to move that big back tire. Maybe a bigger rear sprocket with a few more teeth on it might do the trick.
Note: The clutch does not slip
TIA
TIA
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Milled Head (0.020")
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
Re: Bad Clutch Shudder
Did you check the clutch main bearing ?
I recently had two engines where that big roller bearing behind the clutch had excessive play.
Both had clutch operation issues as one of the symptoms.
And funnily both had pretty new baskets with straight cut primaries.
- T.RexRacing
Why a 180? I run a 180 on my 1000CC Aprilia Tuono.
Salvador Dali
Salvador Dali
- RZResurection
It was an exercise to prove to myself I could.T.RexRacing wrote:Why a 180? I run a 180 on my 1000CC Aprilia Tuono.
I realize there is no real benefit to it.
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
- RZResurection
I didn't change that bearing out, but it didn't seem that bad either when i had the transmission apart. I'll check it next time I have it apart.MK wrote:Did you check the clutch main bearing ?
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
Excessive chain slack will come across just like a wonky clutch. Worth looking at the chain, sprockets, and alignment. Also worth verifying the cush drive has no play.
16/40 or 16/41 gearing would be my choice. I run a 45 rear on my RZ500, so I'm just a little odd anyway
- RZResurection
Bad Clutch Shudder
Yeah, I do believe I have to go up a few teeth on the rear. I think ill go the 41 tooth route.silverstrom wrote:Excessive chain slack will come across just like a wonky clutch. Worth looking at the chain, sprockets, and alignment. Also worth verifying the cush drive has no play.
Cush rubbers looked to be in good condition
Odd is ok as long it works for you. Lol
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
- RZResurection
What happened to your last post? Didn't get a chance to reply.silverstrom wrote:Excessive chain slack will come across just like a wonky clutch. Worth looking at the chain, sprockets, and alignment. Also worth verifying the cush drive has no play.
Your a lot less odd in person lol
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
Lol...I went back and read it and it didn't seem as funny the 2nd time so I deleted it.RZResurection wrote:What happened to your last post? Didn't get a chance to reply.silverstrom wrote:Excessive chain slack will come across just like a wonky clutch. Worth looking at the chain, sprockets, and alignment. Also worth verifying the cush drive has no play.
- RZResurection
I thought about this more. I have a 17T front sprocket. What I remember from the gear calculators: 1 up on the front equals approx 3 on the rear.
I'm guessing that I should go up to the 45.
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
- T.RexRacing
The only time my RZ clutch "shuddered" it had 3 broken fiber plates.
Salvador Dali
Salvador Dali
- RZResurection
There are no broken fiber plates. All (virtually) brand new FZ plates.
I just had the clutch apart the other day - all good.
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
- RZResurection
Just for comparison:
17/39 = 2.29 (current)
16/41= 2.56 (suggested)
17/43= 2.53
17/44= 2.59 (more or less equivalent)
17/45= 2.65
17/43= 2.53
17/45= 2.65
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
Usually when using 17 inch wheels you have to gear up quite a lot due to the different tire radius.
A 160/60-17 is much smaller than a 110/80 or 120/80-18.
In my 17 inch RGV conversions something like 19 / 43 is pretty equal to the stock 17 / 39 with 18 inch. With a larger 180 tire it'll be slightly different maybe 19 / 45 or so.
A good calibration point is 120 kmh in 6'th gear. Stock bikes have 6000 rpm at that point.
If you have less, then your gearing is taller. If you have more, then its shorter.
- T.RexRacing
180/55-17 Circumference-1903MM Pirelli Diablo II
120/80-18 Circumference-1960MM Pirelli Sport Demon
Gearing Commander is a good way to determine the effects of changing wheel/tire size on gearing.
Salvador Dali
Salvador Dali
