You are correct. The 19/43 is equivalent to stock. My issue is there isn't a lot of choice for an 18mm offset sprocket, so I'm going to have to use the 17T front until I can find some other options.MK wrote:Usually when using 17 inch wheels you have to gear up quite a lot due to the different tire radius.
A 160/60-17 is much smaller than a 110/80 or 120/80-18.
In my 17 inch RGV conversions something like 19 / 43 is pretty equal to the stock 17 / 39 with 18 inch. With a larger 180 tire it'll be slightly different maybe 19 / 45 or so.
A good calibration point is 120 kmh in 6'th gear. Stock bikes have 6000 rpm at that point.
If you have less, then your gearing is taller. If you have more, then its shorter.
I knew that keeping the stock gearing and going from an 18" to 17" wheel would give me a little taller gearing. I did plug in the data from the stock bike as well as my 'current' and 'custom' into gear commander and it did show this. It shows 0.54 % in RPM
I'm thinking going to a 43T on the back. That will produce an 11% higher RPM difference from stock. I don't have to worry about speedo issues as I have a GPS speedo.
If I go with 44T = 13.5% diff higher RPM
If I go with 45T = 16% which is significant
I want to try 2 sprockets, but which ones?
I'm thinking the 43T for sure and maybe the 45T. This should give me enough of a spread to see what I prefer.
