LC2 Swingarm Bush
nath
LC2 Swingarm Bush
#1 Post by nath » Wed Feb 10, 2016 12:58 am
Any advice on removing the bush from the LC2 swingarm, So far I've tried a slide hammer with heat applied but its well and truly in there.
Thinking I might have to rig something up in the press
Replacements available from Yambits
http://yambits.co.uk/rd350-ypvs-lc2-swi ... 21715.html" onclick="window.open(this.href);return false;
http://www.ebay.ie/itm/Genuine-Yamaha-R ... SwAYtWNj9E" onclick="window.open(this.href);return false;
Re: LC2 Swingarm Bush
#2 Post by JonW » Wed Feb 10, 2016 1:07 am
you need to remove the central collar first, should push out even when rusty, then you can drift out the bushes from the other side.
nath
#3 Post by nath » Wed Feb 10, 2016 1:20 am
JonW wrote:you need to remove the central collar first, should push out even when rusty, then you can drift out the bushes from the other side.
Yea, figured as much, taken out plenty of the later model bearings with no dramas, these are just being a far more troublesome.
#4 Post by JonW » Wed Feb 10, 2016 1:39 am
Ive had a bunch of these that have been hard work over the years but really heat and the right amount of force will sort them :)
nath
#5 Post by nath » Sat Feb 13, 2016 4:32 am
Man.. what a PITA...
Nothing I had in the tool box would get the little bastard out.. Couldn't find a suitable drift/punch so ended up at Bunnings buying a piece of metal rod, chopped it to size, hardened one of the ends, $7 well spent.
Heated the Swingarm up on a gas burner and managed to get one out with a decent amount of effort, no way the other one was coming out the same way... with the one bush out though I could get a socket in with a similar OD in there and got the swingarm in the press which persuaded the other bush out..
#6 Post by JonW » Sat Feb 13, 2016 8:21 am
wow, never known them to be this hard to remove. you could also have cut the bushes with a saw blade to weaken them of course. Ive known needle roller cages to be hard work, but never bushes :(
nath
#7 Post by nath » Sat Feb 13, 2016 10:55 am
Yea, these were the easily hardest things I've ever hd to get out of any RZ component.
They appear to have Red Loctite (or something similar thats red) on them, wasn't expecting that from the factory so perhaps added by someone later.
Could be the case that I didn't get them to 260 deg. to break the bond so was fighting it the whole time.
yamasukiman
#8 Post by yamasukiman » Sat Feb 13, 2016 9:48 pm
Hullo Nath,
I don't know where you are but if you want a spare swingarm I'll give you one!
nath
#9 Post by nath » Sat Feb 13, 2016 11:38 pm
Thanks for the offer mate, I have a few spare myself already though :)
I'm building an LC2 at the moment, I was tempted to use one of the spare 84'+ ones I have, so much easier as the bearings are easily obtainable and I have some good pivot shafts.
Decided to stick with the original for better or worse with its pitted bushes and pivot which i'm replacing.
Long shot but If you or anyone else local has a 83' LC2 pivot shaft thats in serviceable condition it would save me some $$$ over a new one, Yambits has the set for $140
http://yambits.co.uk/rd350-ypvs-lc2-swi ... rrency=AUD" onclick="window.open(this.href);return false;
#10 Post by JonW » Sun Feb 14, 2016 6:44 am
you should put your location in your profile nath, i cant remember where in Aus you are... not that i have one... they rust pretty readily :/
new OEM they are not that expensive... in US$.
http://www.partzilla.com/parts/detail/y ... 00-00.html" onclick="window.open(this.href);return false;
nath
#11 Post by nath » Sun Feb 14, 2016 8:02 am
Done.
Thanks, Yea, I noticed that, I have to do an order from Yambits and with the exchange rate its much the same.
#12 Post by JonW » Sun Feb 14, 2016 8:34 am
Is the yambits part OEM? if so thats cool.
Also check youre ordering the right part against the parts book for your bike no matter who you order from, im not sure if theyre different or not and I think they are not, but it would suck to buy the wrong one of course.
whyzee79
#13 Post by whyzee79 » Sun Feb 14, 2016 5:42 pm
I had one really stuck on an H2. I had to use a small hacksaw blade and carefully cut a groove through the insert. It then folded up like a piece of wet cardboard once the cut was made. It was a pain and it took a long time cutting by hand but it worked.
#14 Post by JonW » Sun Feb 14, 2016 6:51 pm
The worst one I had with this part of the bike was on a DT200R when the swinger bolt/pin rusted to the collar thats runs thru the bushes, I had to cut the pin off at both ends! span the pin and rested a hacksaw blade on it jammed between the frame and the seals :(
seahorse
#15 Post by seahorse » Fri Feb 19, 2016 6:55 pm
Good to see you have been re born and posting here Nath.
I read many of your contributions on Psb over the years.
Kind regards
Seahorse
Karrinyup
81Rd350lc resto 2016
81 Rd250lc resto 2017
1999 ZRX 1100
