#18 Cover, Hub Dust 481-25118-01-00
I'm having trouble identifying this part that I found in the front wheel. Wondering if it's number 18 on the RZ350L diagram? Number 18 is not on the RZ350N diagram. Here's a close look at the part:
Who Knows This OEM Part?
Re: Who Knows This OEM Part?
The part looks like the shield from a bearing. But there's no writing on it, which seems odd.
It's normally pressed lightly onto one end of the bearing spacer to keep it centered in the wheel. I'll snap a pic of one for you.
It's part of number 2 on the parts diagram. It's for centering the spacer
Here you go, front and rear;
They are both 2mm from the end of the spacer.
haha, its so much more obvious once you see the part together. I had no idea until that last picture and now exactly remember putting that together!
