It is currently Wed Jun 20, 2018 6:09 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Oct 17, 2017 12:26 pm
What size bushing did you use for your 2015 r1 shock I just bought one and need to get the bushing
PostPosted: Tue Oct 17, 2017 9:01 pm
Shilo,
I ordered the R6 bushings from Economy Cycle. Installed the lower bushing for now and will probably install the top ones. I drilled out the stock R1 bushing but it is thin. There are similar bronze bushings at Ace Hardware. Right now I am waiting on Race Tech to see if they can re-valve this shock for the RZ. Ed
PostPosted: Wed Oct 18, 2017 1:23 am
2wheeldrift wrote:
Shilo,
PostPosted: Wed Oct 18, 2017 1:25 am
I ordered the bushings from mc master and I got them the same day they rock $8.50
PostPosted: Fri Oct 27, 2017 1:50 pm
Agreed. Usually get my parts within 2 days from MC.
Only downside is shipping is usually about $15 minimum.
What part numbers did you use?
PostPosted: Tue Nov 07, 2017 10:13 am
Does anyone know if this set-up will work with a VJ23 swingarm? I'm concerned with the reservoir tank hitting the swingarm given there is much more bulk around the axle bolt with the VJ23 than with the stock swingarm.
PostPosted: Tue Nov 07, 2017 9:29 pm
I had an R6 shock on my 350 and recently installed an RGV swingarm with a Penske shock. There is no way the R6 shock could have been used as the reservoir was nearly touching the swingarm. The reservoir position on this one looks similar enough that I would doubt it could be used, a remote reservoir shock like the RGV used is better for that application.
