I've got two oem shocks and want to build one using the best parts from the two. After one compresses the spring, how do you take the shock apart? I figured I'd ask before I start turning/twisting the lugs on the end of the shocks.
Thanks.
Diassembling stock 1984 RZ350 shock?
Re: Diassembling stock 1984 RZ350 shock?
Ignore my question above. After taking a closer look (in the light and while wide awake), I see that lower collar is slit in half. Once you compress the spring enough, the collar should be easy to remove.
