Anyone know if this will work? From what I can find they are both 35mm forks. Was thinking the fork spacing would be the same as well.
Saw a RZ250RR Top Clamp on eBay for $25, wanted to use for when I get Clip-Ons possibly.
Looks like this - http://thumbs.ebaystatic.com/images/g/8 ... s-l225.jpg" onclick="window.open(this.href);return false;
RZ250RR Top Clamp on RZ350 US Model?
Re: RZ250RR Top Clamp on RZ350 US Model?
I just replaced the top clamp on a '87 RZ350 with one off an US model RZ. I suspect you could do the opposite and install a top clamp from a later RZ on the US model.
Frank Tarpley
1988 TDR250, 1974 GT380, 1968 Cobra, 1984/1987 RZ350, 1983 BMW R80st
Interesting.
I wonder if a later model RZ top clamp with clip ons could keep the same headlight/cluster mounting.
That's really what my goal was. To Keep the Stock Mounting for everything but find a top clamp that would work so I could install clip-ons. I'm afraid the RZ250RR doesn't have all the mounting built in to the clamp.
Interesting.
Not exactly , the top mounting points are different but with small brackets you can do it easily , I have a 1985 CDN with this top clamp and a 1983 H.L. bracket for bikini fairing .
85 + use longer fork tubes , factory clip on goes on top not under .
2nd Zedixe13's comment. My front end was very tall with aftermarket clip ons until I realized there should be enough fork through the upper triple from the original clip on position.
