Can someone pls confirm this is a VJ22 swingarm and OK to us
So I’ve had this swingarm for 13 years and finally want to get around to using it. I think it’s a VJ22, but not sure? Also now that I look at it for the first time in a decade it has more damage than I remember. Does it look like it will be OK to use? How can I tell?
The wheel is a 17x5 ZX6 I was going to try to use I think, but it may be more trouble than it’s worth as I read I can use an SV650 wheel and GS500E cush drive and it’s almost a bolt-on?
Does anyone make/sell a kit with the dogbones and anything else I need to run this swingarm in my RZ350?
Thanks,
Mike
Thanks,
Mike
- IMG_1325-2.JPG (125.19 KiB) Viewed 6884 times
- IMG_1324-2.JPG (83.43 KiB) Viewed 6884 times
- IMG_1323-2.JPG (125.47 KiB) Viewed 6884 times
1984 RZ350(two)
1973 RD350 w/ RD400 rims,forks,swingarm
197? R5 in pieces
197? RD60
1991 KLR250
1963 Austin Healey BJ7
1991 300ZX
1999 E36 M3 ‘vert, 5-spd, 56K miles
2002 XJR stock DD
197? R5 in pieces
197? RD60
1991 KLR250
1991 300ZX
2002 XJR stock DD
Re: Can someone pls confirm this is a VJ22 swingarm and OK t
Bloody hell mate it looks as if someone chucked her @ the scenery more than once.
Looks like the dent closer to the pivot, "may" have changed the geometry but the only way to tell is to build a jig.
Some have made custom dog bones from 7020, (I think) sheet.
Tarozzi fork brace
Tarozzi fork brace
ouch indeed...!
Ok, yes this does look like a P model RGV unit. NK sell the kits for this, or look at my site for the upgrade PDF for the RGVs.
If it is straight then you could consider a carbon cover to go over the damage
Someone does make them , just can't remember who at the moment !
Here it is !
http://www.tygaeurope.com/store/product ... -suz-10086" onclick="window.open(this.href);return false;
Here it is !
You could buy a good swinger for less couldnt you? Just a thought.Headcoats wrote:If it is straight then you could consider a carbon cover to go over the damage
Here it is !
Dave
RZ 250 85 (Waiting)
RZ 250 85 (Parts)
BMW R1100S 99 (Its Red)
BMW R1200GS (Its BIG)
RZ 250 85 (Parts)
Making a jig sounds like a reasonable idea; I have a friend with a welder.
I guess I could fill and sand the dents and paint the arm with a metallic wheel paint, then when I have everythign done buy a clean arm later?
Thanks,
Mike
Thanks,
Mike
1984 RZ350(two)
197? R5 in pieces
197? RD60
1991 KLR250
1991 300ZX
2002 XJR stock DD
197? R5 in pieces
197? RD60
1991 KLR250
1991 300ZX
2002 XJR stock DD
Or, you could pull the dent and fill the gouges !
Find someone who can heliarc and you'll be all set.
Get it anodized if you like for corrosion for what you'd spend on a new one.
Tarozzi fork brace
Tarozzi fork brace
My friend has both MIG and TIG welders, so he could fill any low spots. My concern is metal/bodywork is more of an art and I am missing that gene, lol. Anything mechanical I can do no problem though.wolfman wrote:Or, you could pull the dent and fill the gouges !
1984 RZ350(two)
197? R5 in pieces
197? RD60
1991 KLR250
1991 300ZX
2002 XJR stock DD
197? R5 in pieces
197? RD60
1991 KLR250
1991 300ZX
2002 XJR stock DD
any thought on going with a different swingarm. I had a VJ22 and a VJ23 on my 1990 RZ350. They are find, but you will encounter clearance issues with the pipes if you use GP style and if you use the brackets that bolt into the center stand bracket. I'm using TZR250 3XV swingarm and get rid of the center stand brackets for clearance for the pipes.
1985 RG500(Walter Wolfe)
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
Another arm is not out of the question, I just had this arm up in the attic from 13 years ago and like the banana look. I’m torn on the GP-style pipes. Sometimes I love the look and think I have to have them, then other times I’m not so sure. The regular Lomas pipes look great too, IMHO. I don’t have a centerstand either.giron wrote:any thought on going with a different swingarm. I had a VJ22 and a VJ23 on my 1990 RZ350. They are find, but you will encounter clearance issues with the pipes if you use GP style and if you use the brackets that bolt into the center stand bracket. I'm using TZR250 3XV swingarm and get rid of the center stand brackets for clearance for the pipes.
Thanks for your thoughts,
Mike
1984 RZ350(two)
197? R5 in pieces
197? RD60
1991 KLR250
1991 300ZX
2002 XJR stock DD
197? R5 in pieces
197? RD60
1991 KLR250
1991 300ZX
2002 XJR stock DD
the reason for the banana and gp pipes. also removing the center stand bracket was for Brian Turfrey to have room to build the big cones under the bike
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
