Hi,
I was wondering if i need a special seal kit for my 1985 RD350 (31K with needle swing arm bearings) front and rear brake caliper.
There are a lot of kits for 1983-1984 but nothing for 1985.
Did they change the brakes in 1985?
Found this numbers in the Yamaha parts catalogue for 1985:
51L-W0047-00 (same for all 3 calipers), bit 40€ for each set is quite expensive for 4 rubber rings...
Does anyone know a part number (also other brands) for the seal between the 2 parts of every brake caliper?
From the RD500 I know that Yamaha doesn`t sell this seal but I want to split them up for cleaning and painting and replace the seal later.
Brake piston seal kit
My Bikes:
Yamaha RD500 1985
Yamaha RD350 1985
Yamaha R1 2001
Honda CBR 1000 2006
Yamaha RD500 1985
Yamaha RD350 1985
Yamaha R1 2001
Honda CBR 1000 2006
Re: Brake piston seal kit
For the seals between the caliper halves, there's a company on eBay out of England. Powerhouse-UK
There's different sizes, measure yours before ordering
Thanks for your answer.
I will disassemble them during the next days/evenings.
Did some research yesterday evening.
31K 83/84 brake calipers have just one piston, from 85 to the end of production they have 2 pistons per caliper.
They also need different brake pads.
Found this one:
http://www.2takte.de/product_info.php?i ... bj-85.html" onclick="window.open(this.href);return false;
I just don`t need the pistons...
But if the seals are from Yamaha as shown on the picture maybe worth the money (80€ only for the seals from the Yamaha dealer)
Found this one:
My Bikes:
Yamaha RD500 1985
Yamaha RD350 1985
Yamaha R1 2001
Honda CBR 1000 2006
Yamaha RD500 1985
Yamaha RD350 1985
Yamaha R1 2001
Honda CBR 1000 2006
Yes, the 85 31K has the front brakes of the later 1WW models.
Not 100% sure about the rear.
By the way, which paint do you use to get the original finish of the brake calipers?
Maybe a bit more resistant than the original.
Was thinking about thin epoxy based powder coating.
Doesn`t need to be perfect, the 350 is just my daily driver.
My Bikes:
Yamaha RD500 1985
Yamaha RD350 1985
Yamaha R1 2001
Honda CBR 1000 2006
Yamaha RD500 1985
Yamaha RD350 1985
Yamaha R1 2001
Honda CBR 1000 2006
