It is currently Tue Feb 20, 2018 6:36 am
Post new topic Reply to topic  [ 3 posts ]
PostPosted: Fri Jul 01, 2016 2:17 am
Can't seem to get the bolt loose that holds the pads in the caliper.
Thus far I've tried soaking in WD-40 and Liquid Wrench.
I applied just a bit of heat with a propane torch. (not a lot of heat)
Then I used an impact allen socket.
Still can't get that bolt to budge.
Any suggestions???
The link below is not my caliper. Just using it to show the bolt in question.
http://www.scooterhelp.com/RZ_help/rest ... brake2.jpg
Boyd
2012 Super Tenere :smt003
Starting The 1983 RZ350 Rebuild :smt023
Rebuilding a 1980 BMW R65 :smt041
Just purchased a
2005 Yamaha FJR :smt026
PostPosted: Wed Aug 24, 2016 10:48 pm
Cannot think of anything else. If you are willing to sacrifice all the rubber parts, and a repaint job, heat it up more. Also, use a good allen wrench, and do the heat up process a few times, allowing the hot liquid wrench to work in between.
HOpe this helps.
PostPosted: Sun Nov 20, 2016 9:53 pm
There is a spring in there putting pressure on the pads. Push up on the pads and see if that helps. Maybe a little late. Hopefully you got it.
cron
